15-02-2006, 10:34 AM
True Techie
Convertind VCD -> Divx
Can you tell me a freeware which can convert VCD file(*.dat)
to Divx so that I can burn Divx discs .
Thank u
15-02-2006, 10:47 AM
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
15-02-2006, 02:39 PM
Dr divx is not a freeware, Go for VirtualDub but it gives lots of errors...try vidomi or nandub.
15-02-2006, 03:45 PM
15-02-2006, 07:11 PM
VirtualDub is working fine with me..dont get any problem while converting .dat files..
Get Virtual Dub here : http://virtualdub.sourceforge.net/
Ravi-the Sun
Think Bright,Think Sun
www.ravithesun.c-o.in My Blog
www.sunsoft.c-o.in My Web Home
16-02-2006, 04:10 AM
before converting using virtual dub u need to convert the *dat file to *.mpg
pl note that just changing the extension to .mpg does not help
u need vcdgear to convert dat to mpg it takes just abt 2-3 mins and yes pl tick fix mpg errors in vcd gear before u go for the conversion
now u convert the *.mpg file using virtual dub .
the reason for doing all this is the dat file contains major sync errors which create the errors .
i use winavi 7 to avoid all this ....u can directly convert dat to and other format..it is pretty good and fast too.....but ofcourse quality < virtual dub
cheers
16-02-2006, 09:07 AM
True Techie
Thanx a lot
16-02-2006, 12:06 PM
or u can use GordianKnot,it's OSS therefore it's free.
19-02-2006, 03:42 PM
Use TMPEGenc to convert to mpg
Then use VirtualDub to convert to avi
19-02-2006, 09:51 PM
BTW, Dr. DIvX is a gud tool for convertion.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
20-02-2006, 02:39 PM
Huh..Dr. Divx is bogus...
VirtualDub/Flaskmpeg/Auto GordianKnot....and many more freewares..
goto www.doom9.org for more freeware and good softies for audio video compression and encoding..
www.techlads.com
Paarth.
21-02-2006, 01:13 AM
I couldnt change the Bitrate for Gordion Knot...so the compression was not that good..
I had recorded exactly 2 min. Video from TV...in MPEG format..so it was of size 30 MB...so when i converted it to avi thru Gordion..its made is 14...bas...   ..
and also it took 25 mins..for 2 min..file..
So am using AVS Video Converter..its good and fast..
I love walking in Rain ,because no-one knows i am Crying :|
21-02-2006, 01:37 AM
Ok I have a little different query, I want to convert a DVD movie of 4.2 GB to XViD format of 1CD size, please help.
"Gordon Freeman is a mermaid, he obviously traded his legs for his voice."
21-02-2006, 11:07 AM
@ vmp_vivek
see,
u shld make the 4.2 GB DVD to TWO 700 MB parts (Xvid)...if u make only 700MB xvid then quality degrades upto 70 to 80% i think...and on p2p networks,torrents also providing 1.36 to 1.4 GB DVD quality XVIDs..so it is better to make it in 2 parts 700MB each...and u will get grt quality...as i have may videos of DVD quality for the given size of 1.3 to 1.5 GB...
do it in FLASKMPEG or AUTOGK or goto www.doom9.org and find any other tool by reading its review..
one other site www.videohelp.com can help u...
regards,
Parth Barot.
www.techlads.com
Paarth.
21-02-2006, 07:58 PM
@parth,
I know how to make it in 2cds for 700 mb each and thus, 1.2 gb total of two cds, but I have seen many times that they are merged into one. So can you please now suggest me how to merge them ? Thanks.
21-02-2006, 08:18 PM
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
22-02-2006, 06:36 AM
^^ Thanks a lot dude.
22-02-2006, 04:19 PM
for merging many tutorials on www.videohelp.com and www.doom9.org..
using virtualdub, u can easily merge it.
regards,
www.techlads.com
Paarth.
Search this Thread |
