Old 29-10-2004, 02:03 AM   #1 (permalink)
Default Error error error....gives me hell of a terror
hi digitizens,
I have a computer..that restarts every now and then & gives me its favorite error message.. windows has recoverd from a serious error..!!.(gives me memory dump Error on blue screen)Specially when i try to play DVD's...or games...I have limited tech Knowledge...so i did all the stunts that i cud... disabled auto restart on error...error reporting..Msconfig..Upgraded to Xp from 2000. nothing is working.Even checked the mobo temprature processor fan looks fine..reseated Ram & Laxman.increased the virtual memory..Initial & maximun to 1024...!!.did all the circus that can be done on bios...
the specs of my computer
Amd Athlon xp 2400+
256 ddr sd ram @ 333 Mhz(what is 2700)
ASUS A7N8X/VM..with onboard Gpu..GeFprce Mx 440
40 gb Hdd
Creative SoundBlaster live 5.1
Labtec arena-530 4.1 speakers
Windows Xp Sp2
Sooo, Anybody interested in helping me or shud i throw this comp on the face of the bugger who gave the intelligent idea of switching to Amd Athlon...Amd may be rocking..Not for me..!!!
abhilash is offline
Old 29-10-2004, 09:15 AM   #2 (permalink)
try the steps here and tell the results
http://www.thinkdigit.com/forum/view...041&highlight=
- have u disabled onboard sound when using creative
- try running with onboard sound
- reduce graphics memory allocated to 16 and reduce agp apeture value in bios
- whats the error u get in event viewer at the time just before the restart happens ?
get everesthome to check correct cpu temp . asus probe isnt good
klinux is offline
Old 05-11-2004, 10:04 PM   #3 (permalink)
hi,
thanks man.. tried everything u did..cant find anything suspicious...
tried to upgrade ram to another 512 ddr 333mz..
then Whoosh kaboom... bad bios...
then no bios...
Mobo gone bad...
tried to go to bios..Nothing coming up...
send to asus for repair....
which is the best mobo i shud go for.....
I had mercury before...Never had any problems
abhilash is offline
Old 05-11-2004, 11:45 PM   #4 (permalink)
i think i need to send my M/B too for service koz of this IDE controller keeps disappearing . How long did the ppls at asus say it would take to get the m/b serviced ??? if they can't fix it will they replace it with a refurbished or new one of same model . am in chennai , so would that take longer to get the m/b .
klinux is offline
Old 06-11-2004, 12:41 AM   #5 (permalink)
hey my vendornut told me that its gonna take a week to get it repaired...
lets wait till tuesday or m gonna buy a new one... or lemme try to flash the bios & see...
amd is cool my frnd has 1800+
asus motherboard
512 ram & No problems till now..
I dont understand y its me??
abhilash is offline
