Old 14-02-2006, 06:26 PM   #1 (permalink)
ramprasad's Avatar
Default Unable to play VCD
Hi
I have a P4, Win XP machine with a CD-RQ and OEM version of Nero Express 6.
Recently, I bought a VCD. When I tried to put the CD on the drive and try to view the contents, it is shown as a Blank disc.
I tried to make an image, but no use.
Any help would be appreciated.
Reagards,
Ramprasad
ramprasad is offline
Old 14-02-2006, 07:37 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
does the vcd work in vcd players? is the vcd original?
Charan is offline
Old 14-02-2006, 09:02 PM   #3 (permalink)
phatratt's Avatar
maybe u r cheated,the seller must have sold u blank disks.See if can record anything on it also see the howmuch space it has and left.Try playing it in a VCD player.
phatratt is offline
Old 15-02-2006, 08:09 AM   #4 (permalink)
ramprasad's Avatar
I didnt check with any VCD players, but the size is shown as 702MB on "My Computer"
Old 15-02-2006, 11:17 AM   #5 (permalink)
try visual inspection
look at the shining side of the CD to determine whether it has been written or not.
and checking it by playing it in a VCD player is a good idea
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 15-02-2006, 11:20 AM   #6 (permalink)
the cd must be a corrupt one,it happens in such cases and yes do try to play it in standalone player.
acerishabh is offline
Old 16-02-2006, 12:27 AM   #7 (permalink)
shashanktyagi1's Avatar
Default Re: Unable to play VCD
Originally Posted by ramprasad
Hi
Reagards,
Ramprasad
chk if u can play other cd's. if yes then the cd is corrupted. if it cant be played even on vdp players then get it exchanged from the shop. they usually do not promise of it playing on compu but yes ofcourse of being played on players.
shashanktyagi1 is offline
Old 18-02-2006, 09:34 PM   #8 (permalink)
Distinguished Member
anandk's Avatar
i too have winxp/sp2, nero6. but do u have the requisite codes ? i did not, hence was unable to see the vcds/dvds. u either have to download them or instal 'cyberlink powerdvd'. it installs the codecs too. now i can see the vcd/dvd movies. u may also have to do the same.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-02-2006, 10:25 PM   #9 (permalink)
readermaniax's Avatar
HEy it might be a DVD ....it will show blank disc if inserted in a cd rom
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
