Old 14-02-2006, 01:35 PM   #1 (permalink)
Default is it true
i assembled my system a 4months ago, i buy a 80gb seagate sata hdd.my assemebler says never convert newer drives to ntfs system instead convert them to fat,try to convery after sometime,but then i reinstall os ,is it safe now to convert into NTFS file system.he says if u convert it early u will never be able to erase ur hdd.is he idiot.
nvidiasingh2006mb is offline
Old 14-02-2006, 03:11 PM   #2 (permalink)
String Phreak
mediator's Avatar
Well most assemblers are hardware experts, dont know anything about OS functionalities or softwares!
Mtnl ppl who came to myplace to install broadband...I asked them how to install this thing on Linux..They said,"Whats Linux?".cool huh! "So feel like GOD and forgive em" ! (Slogan from that bike ad! )
Neways my recommendation is not to go for NTFS as I have faced numerous problems with NTFS like hidden partitions with NTFS cozing windows not to boot up, succeeded by formatting of PC!!
mediator is offline
Old 14-02-2006, 03:26 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
NTFS gives no problems watsoever and time is not a factor of filesystem format...
But if u use a boot disk often, u need a boot-cd for NTFS specially...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 14-02-2006, 04:54 PM   #4 (permalink)
bizzare_blue's Avatar
i myself have a 80 GB SATA drive and from the very beginning I have converted it to NTFS....n my dear....haven't faced any problems as yet ....n for that matter...I feel its better than FAT32...
Bitten by the open-source bug...
bizzare_blue is offline
Old 14-02-2006, 05:47 PM   #5 (permalink)
champ_rock
champ_rock's Avatar
if that was the case then microsoft would have been shut up by now..... (viruses creating so much prob.. and then here comes ntfs giving prob
i have created ntfs on both my old and new disks... never got any problem
Registered Linux user number 400618
champ_rock is offline
Old 14-02-2006, 05:50 PM   #6 (permalink)
kumarmohit's Avatar
Default Re: is it true
Yes becoz as per QM filesystem has no concerns in the regard of time
kumarmohit is offline
Old 14-02-2006, 05:54 PM   #7 (permalink)
Learner
Kniwor's Avatar
he deserves to be called an idiot.......
this is purely illogical..
Kniwor is offline
Old 14-02-2006, 07:40 PM   #8 (permalink)
String Phreak
mediator's Avatar
Yea , U guys may be lucky enough.....but my affinity is with Fat32 !
mediator is offline
Old 14-02-2006, 08:59 PM   #9 (permalink)
phatratt's Avatar
u can safely convert the file system to ntfs,no problems regarding data loss or corruption.
phatratt is offline
Old 15-02-2006, 12:10 PM   #10 (permalink)
covert it it does not give u any error
vinaypatel is offline
Old 16-02-2006, 04:17 AM   #11 (permalink)
i formated my hdd from the start to ntfs and its better becoz the fragmentation is less than fat32...so defragmentation is faster and needed less often...
that's my view....
cheers
manmay is offline
Old 16-02-2006, 08:05 PM   #12 (permalink)
NTFS rocks completely guys... data transfers are quite time-efficient ... in comparison wit fat32..
---------Peace--------
*.* - DJ AmaZe - *.*
DJ AmaZe is offline
Old 16-02-2006, 08:43 PM   #13 (permalink)
that's my view....
cheers
Same in my case also!
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 16-02-2006, 09:12 PM   #14 (permalink)
bit
bit's Avatar
You don't need NTFS, if you don't use its features such as encryption, compression, user-permissions.
On FAT32, maximum size a file can be is 4GB. But in NTFS a file can be as large as its Partition size. So if you want to work with DVD ISO images then you may need a NTFS partition with larger than 5GB.
(Disk journaling ?)
NTFS maintains a log while committing changes to filesystem. It uses this log in case of power failure or other system problems to repair and maintain integrity of file system. On other hand, FAT32 lacks this feature and runs chkdsk or scandisk when system is restarted.
It is false that NTFS gets less defragmented. No file system is free from fragmentation and IMO NTFS gets fragmented more than FAT32.
Yes, Defragmentaion softwares such as diskeeper defrags NTFS file system more quickly than FAT32. Because Diskeeper just defrags files on NTFS but on FAT32 it places recently accessed files in begining of the partition, hence it takes longer to finish the job. But PerfectDisk and some other does not work in this way and takes as much as time it takes for NTFS to complete the job.
It is natural that M$ recommends NTFS over FAT32, because of its security.
bit is offline
Old 16-02-2006, 09:15 PM   #15 (permalink)
left this forum longback
praka123's Avatar
IS HPFS exists now?Hearrd ntfs got something relatede to it.
praka123 is offline
Old 16-02-2006, 09:41 PM   #16 (permalink)
bit
bit's Avatar
http://en.wikipedia.org/wiki/HPFS
bit is offline
Old 19-02-2006, 02:32 PM   #17 (permalink)
Well i think there are 2 types of fragmentation - Internal and External just like with Main Memory.
In Internal Fragmentation:
FAT - Partitions above 16GB has a cluster size of 16kb.If you have a notepad file of say 1kb,like many windows/system/log files you will be wasting disk space.It may not seem much but it get accumulated over a period of time.
NTFS - cluster size is user defined
rachitar is offline
Old 19-02-2006, 05:58 PM   #18 (permalink)
Sure for linux guys FAT32 is the real thing they wul love.
ra_rav is offline
Old 19-02-2006, 06:01 PM   #19 (permalink)
Why???
rachitar is offline
Old 24-02-2006, 12:50 AM   #20 (permalink)
::vicky::'s Avatar
i cant stop laughing .........no dude u can convert to ntfs very first time
::vicky:: is offline
Old 24-02-2006, 10:31 AM   #21 (permalink)
t3h g04t
teknoPhobia's Avatar
@nvidiasingh2006mb
Buy a gun and shoot ur assembler...NTFS is far better than FAT....also most of those retards do not know about the repair functionality in the XP boot CD which has replaced the need for a separate boot floppy....
technologically challenged.
teknoPhobia is offline
Old 24-02-2006, 11:14 AM   #22 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Well i just converted one of my partitions of my old 40GB seagate to ntfs and no problems yet.
instead i like the compression thing in ntfs partitions very much
Ankur Gupta is offline
