remove the contents of the folder (i.e. remove previous system restore) by doing any of these methods..
drive properties - disk clean up - more options tab - last option will be clear previous system restore points
2nd is
properties of my computer - system restore tab - select turn off system restore so it will delete all restore points from all the drives..
turn it on again once all the points are deleted
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
