Old 28-10-2004, 11:09 PM   #1 (permalink)
sidewinder's Avatar
Default mcafee help!!!!!!!!!!1
hi i am using mcafee 8 virusscan pro as my av soft.After installing it i found it installed a practically meaningless mcafee security centre which si memory consuming.Is there any way i can stop sc from startin automatically every timr i start windows xp without disturbing virusscan pro
sidewinder is offline
Old 30-10-2004, 06:08 AM   #2 (permalink)
sidewinder's Avatar
are yaar do something!!
Old 31-10-2004, 07:38 PM   #3 (permalink)
lavan_joy's Avatar
version 8 sucks.
use version 9
I prefer Norton 2005 for u
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
Old 31-10-2004, 07:55 PM   #4 (permalink)
check if the particular file u want to disable is in admintool services , or msconfig services , the former is prefered
klinux is offline
Old 01-11-2004, 05:55 AM   #5 (permalink)
sidewinder's Avatar
version 9....hmmmm!!! let me see!
Old 02-11-2004, 04:03 PM   #6 (permalink)
Sidewinder.......there is an option whether to have Mcafee to Auto Start or not. Check the Control Panel.
Keep The Passion Alive!
Destructo is offline
Old 02-11-2004, 09:45 PM   #7 (permalink)
Bewitched!
xenkatesh's Avatar
go to RUn Type this
msconfig
go to startup
remove the entry of that AV loader it attempts u to restart do that! it wont load in any more!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities..
xenkatesh is offline
