Old 13-02-2006, 11:21 PM   #1 (permalink)
Default How to know other end's ip while Chatting in YAHOO!!!!!
I think the heading says it all
how to know other persons ip while chatting,in Y!M.
but can u geeks tell me how to do it without transferring of files/pic with her.
also netstat doesn't work
Captain Crime is offline
Old 14-02-2006, 02:30 AM   #2 (permalink)
El mooooo
eddie's Avatar
Not possible. You have to establish a direct connection by either sending files or by starting a audio/video connection.
eddie is offline
Old 14-02-2006, 02:47 AM   #3 (permalink)
El mooooo
eddie's Avatar
Also have a look here
http://support.intel.com/support/mot.../CS-009024.htm
eddie is offline
Old 14-02-2006, 03:44 AM   #4 (permalink)
18 Till I Die............
Hey eddie you got the previous post mixed up, It should go somewhere else.
BTW, if you're sending a file, can you view other person's IP? I just want to know it from security's point of view.
http://www.bash.org/?258908
mehulved is offline
Old 14-02-2006, 09:33 AM   #5 (permalink)
champ_rock
champ_rock's Avatar
yeh........ even sometimes u can view ip info about that computer when u have a direct connection.......
try to use netstat in ms dos
Registered Linux user number 400618
champ_rock is offline
Old 14-02-2006, 10:03 AM   #6 (permalink)
Originally Posted by eddie
What the hell is this.
And for those who re saying its impossible well take a ook at this:
http://www.diamondcs.com.au/portexplorer/
it works,but its a shareware
I want a free solution
Old 14-02-2006, 06:41 PM   #7 (permalink)
El mooooo
eddie's Avatar
Yes. Sending a file and audio chats etc. create a direct connection to the other person. You can just use netstat to view all the connections your PC has made, from which it will be easy to combine whois and know the IP of the other person.
Oh damn! That is what happens when you are sleepy and have lots of tabs opened in your browser.
/NOTE to self: Don't ignore the sleep
eddie is offline
Old 14-02-2006, 06:49 PM   #8 (permalink)
El mooooo
eddie's Avatar
Have you ever used this thing? It doesn't work when you are doing normal chatting. All the chats are routed through Yahoo! servers and you will see yourself directly connected to Yahoo! servers and NOT to the person.
eddie is offline
Old 14-02-2006, 07:37 PM   #9 (permalink)
Well i'm sorry
even i found it tht it doesnt work
Old 14-02-2006, 07:54 PM   #10 (permalink)
String Phreak
mediator's Avatar
Nah its very simple! First u see all the netstat result b4 sending the file etc, then again see the result after sending the file! What is added in the result is the IP of ur chat friend!
mediator is offline
Old 14-02-2006, 08:09 PM   #11 (permalink)
Any such software there for *nix systems?
mehulved is offline
Old 14-02-2006, 08:12 PM   #12 (permalink)
El mooooo
eddie's Avatar
netstat should already be there in your system.
eddie is offline
Old 14-02-2006, 08:58 PM   #13 (permalink)
Go to run
write cmd
and then type netstat
Old 14-02-2006, 10:11 PM   #14 (permalink)
El mooooo
eddie's Avatar
He is talking about *nix systems...like Linux systems. There is no run or cmd here.
eddie is offline
Old 14-02-2006, 10:13 PM   #15 (permalink)
sry.dunno abt Linux
