Old 13-02-2006, 05:18 PM   #1 (permalink)
Default How do I prevent people from installing stuff?
How can I prevent someone from installing any program in my XP Pro account (Admin)? My sister installs cr@p programs that have spyware and I want her to be unable to install any program and I don't want to make a seperate user account for her.
drvarunmehta is offline
Old 13-02-2006, 05:22 PM   #2 (permalink)
hansraj's Avatar
run gpedit.msc and u can have control over lot of things in u r pc....... but log in with administrator privelages....
also u r prob of restricting people from installing using the installer will be solved without using any third party software
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 13-02-2006, 08:08 PM   #3 (permalink)
Can you tell me which specific settings in gpedit do I have to change?
Old 14-02-2006, 01:06 AM   #4 (permalink)
in the group policy
swithch to
Computer configuration>Administrative templates>Windows components>Windows Installer
here u will find a policy named "Disable Windows Installer" enable it
all done
and make sure that in this policy after enabling it ,, it is set to always ,coz by default it is set to never
which will not disable the installer.............
thadhanihemant is offline
Old 14-02-2006, 10:01 PM   #5 (permalink)
Thanks
Old 14-02-2006, 10:44 PM   #6 (permalink)
dIgItaL_BrAt's Avatar
Originally Posted by thadhanihemant
in the group policy
swithch to
all done
but that only prevents software which use the Windows Installer,not software which employ the Nullsoft,Installshield or other third-party installers.
dIgItaL_BrAt is offline
Old 14-02-2006, 11:52 PM   #7 (permalink)
Technoholik !!
Tech&ME's Avatar
in the group policy
swithch to
all done
Try to disable execution of any SETUP.EXE file.
Tech&ME is offline
Old 16-02-2006, 11:05 AM   #8 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
but what about xp home edition??and xp home edtion sp2????
romeo_8693 is offline
Old 16-02-2006, 12:55 PM   #9 (permalink)
GaurishSharma.com
gary4gar's Avatar
best way is turn on the guest a/c
and using user password 2 u can set it to open by default,even u can use it. it is also safe as if a hacker gains control of ur comp he does not have suffient rights to cause widespread damage.I myself use this kind of setting but i have created a account for it . when u got to install something just logoff & logon to admin account
gary4gar is offline
