View Poll Results: Would you like it
Yes 7 70.00%
No 3 30.00%
Voters: 10. You may not vote on this poll
Old 12-02-2006, 11:54 PM   #1 (permalink)
abhinavrakesh's Avatar
Default Challenge For Computer Geeks
How To Add or Remove Commands from Context Menu of XP
or When you right click you see Arrange Icons By, Refresh, New etc. How Can You Add Command in Right Click Menu of Windows XP
abhinavrakesh is offline
Old 13-02-2006, 12:14 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
I thought, u were the GEEK and askin a tricky querry and giving the answer as well, atleast u shud make a start here First.........
cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 13-02-2006, 12:45 PM   #3 (permalink)
Default here it is
clickrun and type appwiz.cplby clicking star menu,this will pop up add or remove. hehehe
nvidiasingh2006mb is offline
Old 13-02-2006, 02:40 PM   #4 (permalink)
Ishan's Avatar
Abhinav's ques is intersesting so i thought u all sud seee it. so i posted this so that post can come at first.
Ishan is offline
Old 13-02-2006, 04:21 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Following is the answer:
Remove Unsolicited Junk From Your Context Menus
U can add items in context menu in the same manner as u remove them!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 13-02-2006, 04:27 PM   #6 (permalink)
__Virus__'s Avatar
k am a bit confused here, did me ask that menu which pops up when u right click item or right away on desktop. I never found a way to add sumthn to rhat menu where refresh, new, properties arrange icon by...resides
__Virus__ is offline
Old 13-02-2006, 04:36 PM   #7 (permalink)
Microsoft MVP
The above trick works, when u right-click on a file/folder/drive, etc. It doesnt work with the desktop...
Old 13-02-2006, 04:53 PM   #8 (permalink)
__Virus__'s Avatar
Yups, was thinking about desktop. If the dood asked about right clicking on file or folder, its lame
Old 13-02-2006, 10:30 PM   #9 (permalink)
Default Ok I Try To Explain
When You Right Click On A File or Folder it shows you some commands like delete etc, now when you delete the file it goes to Recycle bin and if you want to delete the file without sending it to the recycle bin then you press shift then delete it, now my question is if we can add a entry below the delete command like Shred (Shift + Delete) then we dont have to press shift button on our keyboard the file will directly deleted from computer without recycle bin
Old 14-02-2006, 02:58 PM   #10 (permalink)
alib_i's Avatar
For one thing .. you can enable "Shift + Delete" at all times
1- Click Start menu > Run > and type “gpedit.msc� (without quotes ) to run Group Policy
2- Go to following : User Configuration > Administrative Templates > Windows Components > Windows Explorer
3- In right panel, find “Do not move deleted files to the Recycle Bin�, right click and select Properties, in dialog box select Enable check box
This will completely delete files at all times.
If you still want both Delete and Shift+Delete options in right click menu then save the following in a text file and name it as "<anything>.reg"
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shell]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shell\Erase File]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shell\Erase File\command]
@="cmd.exe /c \"del \"%1\"\""
Double click on .reg file and merge.
It wont have the "Erase" command just above "delete" .. but it works .. it opens a command window to execute the "del" command and then the window closes.
alibi
-Metallica
alib_i is offline
