Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
256 MB RAM is not good for XP systems - it is the recommended minimum... Try to get min 512 MB or even 1 GB...
Also, turn off the eyecandy in XP by making it look in classic mode. 1. Right-click desktop and select Properties, go to Themes tab and select Windows Classic... 2. Right-click My Computer and select properties, go to advanced tab and select Settings for Performance, select the option to Adjust for best performance...
I think problem with ur RAM.Berfore going it try to reinstall the os and then try if it continues go for 512 RAM.....
