Old 11-02-2006, 08:24 PM   #1 (permalink)
Default AM suprise my drive D got lost while installing
Folks,
i was intalling win XP in drive C i chosed the right drive but after installing i found out that it was intalled in bopth my drive c : and D: and my whole data got lost.
Any please haeva suggestion or any thing could go wrong . plz let me know
Flip like a butterfly, sting like a bee
Butterfly is offline
Old 11-02-2006, 08:32 PM   #2 (permalink)
Ethan_Hunt's Avatar
Think again did you choose the Repair option by any chance and dumped the new Windows file in your D Drive by any chance? A bit more detail needed as to the exact procedure you adopted to carry out the installation.
V for Vendetta
Ethan_Hunt is online now
Old 11-02-2006, 08:53 PM   #3 (permalink)
phatratt's Avatar
Bro,please elobrate your problem properly.I have some questions
what was the earlier O/S
do u have myltiple o/s??
what filesystem are u using(FAT ot NTFS)
Best bet is run the setup again and check if u have any partition with different filesystem which windows does not support.
phatratt is offline
Old 11-02-2006, 09:10 PM   #4 (permalink)
well,
Before my Drive D was fat now its NTFS and alco c drive is ntfs , umm am preety ssure that dint do repair .
Am really in shock right now well am preety sure that i installed it in drive c , and i di quick format with ntfs .
now whats happening is when i run my comp its giving me to win xp choise well one dosent work .
Old 11-02-2006, 09:52 PM   #5 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
tht happened with me too
tht to not when installing the OS
it just happened and i was shocked
can someone tell why this happens?
vijay_7287 is offline
Old 11-02-2006, 10:17 PM   #6 (permalink)
well this might be the case that, when the system drive ( C:\ ) is unattainable, windows was unable to install or modify system files there and so it opted for drive D, when prompted to quick format, what actually got quick formatted was D and not C as expected.This happens when there's a corrupted OS on C: and u want to quick format it and load windows.
Best way is to format C: using floppy boot and then install windows on fresh formatted C and not on remanant C:
Lest u can do now is format both C: and D: using floppy boot and then install a frsh copy of windows to C:
Techie_Geek is offline
Old 12-02-2006, 02:45 PM   #7 (permalink)
Folks,
I think i found out the cause why the Win XP got installed in D drive instead in C Drive.
While installing i forget to delete the partation.
i dont no am not so sure thich could be the reason.
now second problem is that before i use to install Norton antivirus so easily , now whats happening is that it simply installs it dont even ask for a key .
am really in shock
