Go to C:\Windows\System32\drivers\etc. You will find a file named "hosts" there. Open the file in notepad. It should be something like this:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
Now if suppose you want to block google.com, add the following entry under localhost like:
# space.
# For example:
127.0.0.1 localhost
127.0.0.1 google.com
