Old 11-02-2006, 12:29 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default how can i undo .scr file association ???
hi !
using some security application, i seem to have, quite some time back,
set .scr files to open with notepad. how can i undo this ? when i click on the screensaver logo, gliberish opens
in notepad !
i tried folder options>file associations, but cudnt find .scr there.
pls help.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 11-02-2006, 02:00 PM   #2 (permalink)
If you cant find scr. Then go to new and create new extention as scr.Here click on the advanced tab and u will get a dropdown menu for associated file types and select screen saver.
But my personal opinion is that you are better off opening .scr with notepad rather than giving them ececuting permission.Screen savers are useless programms anyway and most of the virus are sent through .scr docs.
amitsaudy is offline
Old 11-02-2006, 05:48 PM   #3 (permalink)
Use the fix file http://www.dougknox.com/xp/fileassoc/xp_scr_fix.zip - details at http://www.dougknox.com/
Arun
sakumar79 is offline
Old 11-02-2006, 07:41 PM   #4 (permalink)
anandk's Avatar
i agree with u amit, reg virii and .scr.
thnx for ur help sakumar.
thanx a ton guys.
Microsoft® MVP
anandk is offline
