Old 11-02-2006, 11:43 AM   #1 (permalink)
9437077259
go4saket's Avatar
Default How to create menus for DVD movies???
Hello friends!
I have a few movies stored on my HDD out of which I want to create a DVD. As all the movies are already in DVD format, encoding wouldn't be necessary. Now, as I want to add in two to three movies in a one DVD, I need to create menu's for it.
Can you guys guide me as to how can I create menus and which is the software that can help me in this. I tried Nero, but th4ere seems to be some problem with it as every time I try it, it's gets held up which encoding agian. As I already have the files in DVD format, is it possible to create a menu without encoding the movies again?
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 11-02-2006, 01:48 PM   #2 (permalink)
lF the movies are on your hdd then you will have to encode them again to view them on dvd.So you will havve to wait for nero to do its job(I think).
amitsaudy is offline
Old 11-02-2006, 02:03 PM   #3 (permalink)
9437077259
go4saket's Avatar
Any software other than Nero Recode...
Win 7 Ultimate
go4saket is offline
Old 11-02-2006, 05:45 PM   #4 (permalink)
DVD Lab Pro. It's a professional tool, but easy on newbies too. And lots of guides available on the net (at the usual suspects - videohelp.com, doom9.net).
You will need DVD spec audio and video to begin with because DVD Lab is not an encoder.
Get a demo version and try it.
http://www.mediachance.com/dvdlab/
-Keith
Keith Sebastian is offline
Old 11-02-2006, 08:05 PM   #5 (permalink)
9437077259
go4saket's Avatar
I have DVDlab Pro but it seems to be quite a complicated choice. Is there something simpler...
Win 7 Ultimate
go4saket is offline
Old 11-02-2006, 10:03 PM   #6 (permalink)
All software (like everything else in life ) has a learning curve associated with it. Start by reading a good guide.
http://www.doom9.org/index.html?/mpg/dvd-lab.htm
Trust me, once you get hooked on to DVD-Lab, you won't go looking for any other authoring software. I've used it for years, authoring over hundred DVD's (3.5 kilograms , I know 'cause I weigh them before flying) of stuff captured from digital terrestrial transmissions in Australia and digital satellite stuff here in Arabia (European feeds).
-Keith
Old 11-02-2006, 10:56 PM   #7 (permalink)
u can do wit..Ulead....
Chindi_Chor is offline
Old 12-02-2006, 08:11 PM   #8 (permalink)
there are many softwares like nero vision express and sony vegas.
Pain is temporary glory is forever
jcmac is offline
