| Forum |
#1 (permalink) |
I have this peculiar problem with my comp. The internet explorer 6 works fine when i have 2 or 3 windows open, max at the same time. However if a fourth or even fifth opens. There is an eror message that says IE experienced a problem and will now shut down, would you like to send an eror report to microsoft" Then another explorer window opens(while all the older ones shut down) and things are back to normal as long as i keep a max of upto two windows open Please help PS.computer has been checked for virusus there seem to be none. |
#3 (permalink) |
Instead of a re-install, try a repair first.
In the mean time start using Firefox. Chances are that you will never return back to IE
:: Free hosting and free domain names available in special cases. Conditions apply :: |
#4 (permalink) |
FooBar Guy
@tuxfan, Firefox is far better, but there's one thing in IE that's still not available in Mozilla family.... Offline Browsing ... it saves a lot of time and online bandwidth.... I think it is not there in Firefox/Mozilla delibrately....
- -- http://www.MovieAB.com - A tiny movie mashup! |
#7 (permalink) |
Coming back to life ..
Please post your HijackThis Logfile for better assesment of your problem.
Sleight of hand and twist of fate... On a bed of nails she makes me wait... And I wait without you ... With or without you .. ---- Batty = Too Busy Now !!! |
#8 (permalink) |
- in msconfig , uncheck mdm
- internet option -> advanced -> check disable debug - else add/rem prog -> ms ie -> repair installation - run drwatson and recreate the error , it might help , else u have an option to view the error report to be sent to ms |
#9 (permalink) |
until ms does not come out with IE7,
its time to say good bye to IE6 use opera, firefox instead i am using opera 7 because of
[ॐ एसएमएस॰सोल्भर ॐ] |
#10 (permalink) |
Experienced the same problem faced by rohanbee, when inserted the October 2004 CD or DVD. But no problems occured when i browsed the CD's autorun feature in opera browser that's why opera rules.....
#12 (permalink) | |
#13 (permalink) |
use opera man.its the fastest browser in the world and it is very interactive. in the new version (7.5) you have many new features which no other browser has.
internet explorer may be the most used but it is stupid man just stupid. try minimising the use of IE . take my case i use IE only for my gmail and for all other websites i use opera |
#14 (permalink) | |
i use firefox 1.0pr. in the file menu i can see the work offline menu as in I E 6.0. ne ideas ?? |
#15 (permalink) |
what about ur RAM? is it too low, or do u have too many programs starting up with windows? this isnt be a problem that today's PCs should face, but if u have an old comp, u might want to increase ur RAM, or cleaning up ur startup(run msconfig).
#16 (permalink) | ||
#17 (permalink) |
opera doesnt support javascripts .. used by gmail ...
its amazing u dont know this by now
What I've felt, What I've known; Never shined through in what I've shown Never free, Never me; So I dub thee unforgiven -Metallica |
#18 (permalink) | |
#19 (permalink) |
Guys one question?
How do i revert back to IE 6 back from FireFox (not that i'vs had any preformance problems with it but........) some sites don't seem to open under FireFox properly (microsoft propoganda who knows?? )
Quote by Garfield' "I hate mornings they start too early in the day" |
#20 (permalink) |
I think both the browsers can co-exist, you don't have to do anything to revert back. Just open the browser you want.
May be you may have to set IE as the default browser which is fairly simple. In IE6 you can go to Tools > Internet Options > Programs. There put a tick next to "Internet Explorer should check to see whether it is the default browser". Restart IE and it will prompt you if IE is not the default browser. There is a similar settings in Firefox in Tools > Options > General Matter of half a minute, isn't it?
#21 (permalink) | |
-- The new Opera 7.6 Preview Release 2: http://snapshot.opera.com/windows/o760p2_7263.exe Im surprised that with the plethora of features in this release (including voice browsing), the file size is just 3.5 MB- While Firefox 1.0 RC is 6.5 MB!!! And Opera also loads much faster in this release. --- @tuxfan: I dont mind the advts- Actually, I dont get any advts http://www.free-webspace.biz/dexter/hosts.rar ---- @rohanbee, if you want to open sites that do not open properly in Firefox, then you can try out the latest version of Opera - almost all sites now open properly in Opera..
Yes, I\'m back. Not 24x7 yet, but pretty soon. Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum. Any inconvenience caused is regretted. |
#22 (permalink) |
yes dexter .. me using Opera 7.54
didnt upgrade as its a preview release ... and moreover i cudnt get hold of crack of 7.6 version the opera site www.opera.com still says the last official release is 7.54
#23 (permalink) |
Well, this is the offical release, only its not the official "public" release. But having looked at the extremly comprehensive change log, it seems pretty stable and the features are well worth it.
And thanks to the friendly serial-key system used by Opera, theres no need to find a crack for 7.6
| Bookmarks |
| Display Modes | |
