Old 10-02-2006, 07:52 PM   #1 (permalink)
Default SQL server ERROR
Hello Friends,
I am getting the error [DBNETLIB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied in my SQL server. The SQL server is running and everything is fine i mean all the services are running. Same coding and script was running fine till date and also i have not changed any settings. Kindly help me in solving the problem.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 10-02-2006, 08:14 PM   #2 (permalink)
rajesh's Avatar
Hope this helps
http://support.microsoft.com/default.aspx?kbid=328306
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
Old 11-02-2006, 02:00 PM   #3 (permalink)
::cyborg::'s Avatar
r u using sql 2000
::cyborg:: is offline
Old 11-02-2006, 03:23 PM   #4 (permalink)
what ur serverce manager says
try to login in sql query analyser
try to use sql authentication
or uninstaall and instal it in mix mode
vinaypatel is offline
Old 15-02-2006, 12:20 PM   #5 (permalink)
I rebooted the server and the problem was solved.
Old 16-02-2006, 12:04 PM   #6 (permalink)
royal's Avatar
if u r accessing SQL Server from a client machine , then sometimes u need to "connect" to the server from the client machine before u connect to SQL Server
for e.g. u can go to Start> Run and type //Server and press enter then login to Server with userid and password (assuming name of ur server is "Server")...
this has helped me ... hope it also helps u
royal is offline
