hi,
i have 2 partitions. in one i have win2k and the other has linux. now i want to remove the linux os. so will this procedure be ok?
1. boot from a bootable floppy and go to command prompt and give
the command fdisk /mbr.
2. give fdisk command and delete the linux partition.
3. create a new partition from the free space got from deleting the linux
partition.
or should i do any thing more?
ps:currently my first boot is set to linux.
thank you.
