Results 1 to 12 of 12
28-10-2004, 12:03 AM #1
Help 4 setting up New HDD and DVD ROM
Hi Mates,
Today I bought Seagate Barracuda 80 GB +7200 RPM HDD [for Rs. 2900] and a Liteon DVD-ROM 16x Drive [for Rs. 1750 >Black].
I already have a 40 GB + 5400 RPM Seagate baaracuda HDD, LG CD-ROM Drive 52x and Samsung CD-ReWriter 40x-12x-40x. I have Intel 815e Motherboard with 1GHz celeron Processor. Runnning XP. Let me know how should i Connect the DVD ROM and HDD For Max Performance!!
Thx in adv.!!
Beware of my Wrath Mortals, Thou hast no choice.
28-10-2004, 08:21 PM #2
Re: Help 4 setting up New HDD and DVD ROM
Hmm...
Originally Posted by Thor
Well i wud suggest that u connect them as follows
Pri. Master = 80GB HDD
Pri. Slave = 40GB HDD
Sec. Master = CDRW
Sec. Slave = DVD ROM
Since u also has a CDROM.. i dont think u'll be able to use it since u'll hav only 2 IDE channels.so u will hav to ditch the CDROM drive...
practically there is no performance difference btween master/slave so u cud switch the CDRW and DVD ROM positions unless ur CDRW faces some probs gettin detected
Its nice to be back....
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
28-10-2004, 11:31 PM #3Wise Old Owl
- Join Date
- Aug 2004
- Location
- New Delhi
- Posts
- 1,150
i would recomend
pri master 80gb
pri slave DVD
sec master cd
sec slave 40 Gb
why?
better throughput while copying CD on the fly, better IDE channel utilisation by the HDDs**** happens
28-10-2004, 11:37 PM #4Alpha Geek
- Join Date
- Sep 2004
- Posts
- 625
would using a 80 conductor ide cable for this config give udma 5/6 for the hard disks and keep udma 2 for dvd/cd ? or would they all work under udma 2 ?
Originally Posted by pradeep_chauhan
29-10-2004, 01:07 AM #5Wise Old Owl
- Join Date
- Aug 2004
- Location
- New Delhi
- Posts
- 1,150
i use a similar setting and use a 80 con cable on both ide channels and get ultra dma 5 on both hdd and a pio for the opti drives
**** happens
29-10-2004, 01:09 AM #6
Thx,
Will my Motherboard Support Raid 0 ?
What is it actually?Beware of my Wrath Mortals, Thou hast no choice.
29-10-2004, 10:13 PM #7Right Off the Assembly Line
- Join Date
- Aug 2004
- Posts
- 36
More information read thisHard Disk and ATAPI Device Channel Sharing: There are several reasons why optical drives (or other ATAPI devices) should not be shared on the same channel as a fast hard disk. ATAPI allows the use of the same physical channels as IDE/ATA, but it is not the same protocol; ATAPI uses a much more complicated command structure. Opticals are also generally much slower devices than hard disks, so they can slow a hard disk down when sharing a channel. Finally, some ATAPI devices cannot deal with DMA bus mastering drivers, and will cause a problem if you try to enable bus mastering for a hard disk on a channel they are using.
http://www.pcguide.com/ref/hdd/if/id...erformance.htm
Well this make me change my setting to all optical drivers on secondary IDE channel, unlike what u hav mentioned
She moves like she dont care...smooth as silk cool as air..!
29-10-2004, 11:11 PM #8Wise Old Owl
- Join Date
- Aug 2004
- Location
- New Delhi
- Posts
- 1,150
See the daye of the site
The PC Guide (http://www.PCGuide.com)
Site Version: 2.2.0 - Version Date: April 17, 2001
© Copyright 1997-2004 Charles M. Kozierok. All Rights Reserved.
thats history, use the setting i suggest and use a utilit like hdtack to do a throughput test you will see what i mean.**** happens
29-10-2004, 11:46 PM #9
[quote]I already have a 40 GB + 5400 RPM Seagate baaracuda HDD
what??????????
5400 rpm seagate hdd's are not baracuda they r normal ones.
30-10-2004, 12:34 AM #10Alpha Geek
- Join Date
- Sep 2004
- Posts
- 625
- how have u physically connected the 80 con cable to both drives . normal way would be
blue -> m/b , grey -> optical , black -> hdd right ?
my cable isnt that long and hdd and cdrom too far apart so i had to reverse it
blue -> dvd , grey -> hdd , black -> m/b .
and with this i get the 80 conductor missing error even with an 80 con cable
plus hdd works only in udma 2 setting .
i am unable to use ide controller 1 koz drives connected to it keeps disappearing so i have only ide controller 2 to attach both drives and i want hdd to work with udma 5 .
- if i get a pci ide controller , would i still be able to boot normally with a bootable cd by the boot sequence in bios ? or will the cdrom detect only after i load the os
30-10-2004, 12:51 AM #11Wise Old Owl
- Join Date
- Aug 2004
- Location
- New Delhi
- Posts
- 1,150
see the red wire or the narked side this is the pin one aline this to the pin one on the mobo and on the drive side it is towards the power socket also one pin in the connector is blocked i hope the insertion is right. The connector i use is from a compac m/c and i have an ibox cabinet where the wire length is fitting ok.
**** happens
30-10-2004, 01:43 AM #12Alpha Geek
- Join Date
- Sep 2004
- Posts
- 625
ide connectors are keyed connectors . it works fine except i cant get udma 5 when i use it with a drive on same cable , if it is connected without a drive i get udma 5 . anyways any idea on how much pci ide controller costs ?
Setting up SVN
By bapixx2 in forum ProgrammingReplies: 4Last Post: 26-01-2009, 01:36 PM -
Setting up VPN
By Plasma_Snake in forum QnA (read only)Replies: 2Last Post: 08-04-2008, 06:29 AM -
>==>> Help in setting up LAN <<==<
By pushkaraj in forum NetworkingReplies: 16Last Post: 15-07-2007, 01:46 PM -
Setting DC++ HUb
By deadpulse in forum Software Q&AReplies: 1Last Post: 19-02-2007, 11:09 PM -
setting up net
By vandit in forum Open SourceReplies: 1Last Post: 24-09-2005, 09:22 PM
LinkBack URL
About LinkBacks
