Today I got the Feb. 2006 issue of Digit and read the Fastrack to Windows XP Maintenance and Management. I checked the C drive with what the book says Scandisk and Chkdsk command from C prompt and it showed that the Volume C: is clean. Then I defrag C: with the Windows disk defragmenter as well as from the Command Prompt but the same error message appeared saying, "Some files on this drive could not be defragmented. Please check the defragmentation report for the list of these files". This is the report:
Volume MAIN (C
Volume size = 7.01 GB
Cluster size = 4 KB
Used space = 5.36 GB
Free space = 1.65 GB
Percent free space = 23 %
Volume fragmentation
Total fragmentation = 14 %
File fragmentation = 27 %
Free space fragmentation = 1 %
File fragmentation
Total files = 29,807
Average file size = 274 KB
Total fragmented files = 3
Total excess fragments = 21
Average fragments per file = 1.00
Pagefile fragmentation
Pagefile size = 1.00 GB
Total fragments = 4
Folder fragmentation
Total folders = 1,872
Fragmented folders = 1
Excess folder fragments = 0
Master File Table (MFT) fragmentation
Total MFT size = 44 MB
MFT record count = 31,847
Percent MFT in use = 70 %
Total MFT fragments = 3
I also checked the registry with Registry Mechanic which reported some 200 broken.... needs to be fixed but since the software was only a trial version reparation could not be done. Although I dont know any problem that this defrag problem has caused on my computer I am uncomfortable with it.
