Old 07-02-2006, 12:56 PM   #1 (permalink)
::cyborg::'s Avatar
Default scandisk blues
iam getting sick of this problem when i run chkdsk from windows it says that "chkdsk cannot be started as window is using the drive c: so u do want to schedule the chkdsk to start when system is restared??" on saying yes system restarts and shows "cannot directly access the drive" and shows welcome message and there comes my desktop
iam using windows xp
swap file is on d: drive
iam having 2 drives only c: and d: from which c: is ntfs and d: is fat32
plz help what could be the problem????
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
::cyborg:: is offline
Old 07-02-2006, 05:14 PM   #2 (permalink)
Hi.
Try to scan your D:. If its happening, you will have to reload your widows XP.
prabodh is offline
Old 07-02-2006, 05:18 PM   #3 (permalink)
Default Re: scandisk blues
Hi.
Try to scan your D:. If its happening, you will have to reload your widows XP[/quote]
prabodh is offline
Old 07-02-2006, 05:35 PM   #4 (permalink)
saiaspire
Posts: n/a
Default NO PROBS
This error occurs, since windows is loaded on c: and thus it is mounted and chdisk is unable to unmount it. So just schedule chkdisk and restart ur PC to check.
Old 07-02-2006, 10:28 PM   #5 (permalink)
Let the music play.....
djmykey's Avatar
Default Re: NO PROBS
Dood how would you unmount windows and then run scandisk
Hell dis thing doesnt run even in Safe mode I tried it out rite now. It runs fine on other drives but not on c:. Try using another scanning software.
djmykey is offline
Old 08-02-2006, 12:53 AM   #6 (permalink)
El mooooo
eddie's Avatar
http://support.microsoft.com/?kbid=823439
Time to install SP2
eddie is offline
Old 09-02-2006, 11:52 AM   #7 (permalink)
::cyborg::'s Avatar
hey man i have xp with sp2
Old 09-02-2006, 10:27 PM   #8 (permalink)
El mooooo
eddie's Avatar
Ok. Which AntiVirus and Firewall are you using?
eddie is offline
Old 09-02-2006, 11:06 PM   #9 (permalink)
::cyborg::'s Avatar
no firewall and no a/v
