06-02-2006, 06:45 PM
Please answer........... Chetan
Anybody please tell me the model name of DVD-Writer by Sony having DL-DF format. I am waiting for your reply because i am buying.
06-02-2006, 06:46 PM
06-02-2006, 06:47 PM
Chetan
06-02-2006, 07:21 PM
What the hell are you doing with three same posts in 3 minutes?
I don't know any dl/df sony writers, but if I am right, I am not sure you will find one as sony backs blu-ray and not hd dvd.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
06-02-2006, 08:11 PM
i guess he means a dual layer/dual format writer,so that would be the DRU-810A.
06-02-2006, 08:14 PM
What did he mean by DL-DF format?
V.Prem Kumar
V.Prem Kumar
06-02-2006, 11:26 PM
it may be dual layer double side (the 18 gb ones). May be. BTW, My Sony DWQ30A supports it for sure.
Sometime you'll think you understand everything
...Then you'll regain consciousness
06-02-2006, 11:42 PM
By DF, I assume that he means the dual format dvds. From what I know, df dvds have two layers; one layer hd-dvd compatible and the other ordinary dvd compatible. That's why I said sony won't be interested in making it. Is there any other meaning for Dual Format?
06-02-2006, 11:46 PM
dual format means support for both the '+' and '-' formats.
Search this Thread |
