Old 27-10-2004, 03:38 PM   #1 (permalink)
Default Divx Audio Sync Prob
my divx movies audio go out of sync when converted from .mpg format . initially converted .dat to .mpg and the audio is just fine in it . once i convert to divx using flaskmpg , the audio is in sync for around 5 mins and then the audio runs faster than the movie , ie there is a delay in the video and audio doesnt sync . any settings i got to change ?
i cannot use virtual dub , koz it shows an error when i drop the dat and mpg movie . some packet error thing
used same sample rate and fps as the mpg file for the avi output .
used divx 5.2 and mp3/ogg for audio , both give the same prob . any ideas ?
klinux is offline
Old 27-10-2004, 09:31 PM   #2 (permalink)
Version 2.0
Deep's Avatar
check this software
AV-Sync
it shall fix your problem
Regards
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 28-10-2004, 03:25 AM   #3 (permalink)
alib_i's Avatar
i needed that deeply ...
thanx deep
-Metallica
alib_i is offline
