i've xp installed... taskmanager shows svchost.exe runnning....sometimes my pc shutdowns automatically in 60 seconds & also if i end svchost.exe it shutdowns then too... but i don't have blast virus.. so what is it & how 2 cure it...
You probably have another variant or the Sasser Worm. Boot into safemode and goto Administrative Tools->Services Find the RPC service, right click and select properties. Under Recovery Tab, change the drop down boxes to read "Take no Action" for all three of them. click apply. Restart your computer and clean the system with a good AV such as Kaspersky or NOD32. Apply any patches from MS Website.
btw are you using XP SP2 ?
If u get the shutdown message and the countdown frm 60 secs begins just do this.Go to start -> run -> and type " shutdown -a ".That should solve the problem.
why dont u get a patch from any antivirus websites?
well before he gets it, the system reboots... lol
