Any bit torrent client is not able to associate itself with .torrent files on my computer?? The error given is
Failed to Write Data to Registry.
Then clicking on details in Azureus, it show the following:
org.gudy.azureus2.plugins.platform.PlatformManagerException: Failed to write registry details
at org.gudy.azureus2.platform.win32.PlatformManagerImpl.registerAdditionalFileType(PlatformManagerImpl.java:547)
at org.gudy.azureus2.platform.win32.PlatformManagerImpl.registerAdditionalFileType(PlatformManagerImpl.java:470)
at org.gudy.azureus2.platform.win32.PlatformManagerImpl.registerApplication(PlatformManagerImpl.java:442)
at org.gudy.azureus2.ui.swt.views.configsections.ConfigSectionInterface$9.handleEvent(ConfigSectionInterface.java:484)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2713)
at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.<init>(SWTThread.java:114)
at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.createInstance(SWTThread.java:58)
at org.gudy.azureus2.ui.swt.mainwindow.Initializer.<init>(Initializer.java:108)
at org.gudy.azureus2.ui.swt.Main.<init>(Main.java:123)
at org.gudy.azureus2.ui.swt.Main.main(Main.java:142)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
Caused by: org.gudy.azureus2.platform.win32.access.impl.AEWin32AccessExceptionImpl: writeStringValue:RegCreateKeyEx failed
at org.gudy.azureus2.platform.win32.access.impl.AEWin32AccessInterface.writeStringValue(Native Method)
at org.gudy.azureus2.platform.win32.access.impl.AEWin32AccessImpl.writeStringValue(AEWin32AccessImpl.java:87)
at org.gudy.azureus2.platform.win32.PlatformManagerImpl.registerAdditionalFileType(PlatformManagerImpl.java:496)
... 18 more
Any Help?? I m using WinXP SP2. Full comp specs are here
Have you tried the basics first?
1. Right click the file while holding Shift key and choose Open With..
2. From the list of programs given, choose your Azureus client either by choosing from the list or by clicking Browse..
3. Enable "Always use the program to open such files" and click on OK.
One should always check the basics first before going any furtherer.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
