Old 05-02-2006, 10:23 AM   #1 (permalink)
Pharmaguru
kjuvale's Avatar
Default how to copy Dvd to Hdd
I have DVD of my sister's wedding. As my many relatives do not have DVD player they want it as vcd. But i am not able to copy it on my HDD, it gives me error while copying. i have not set any region no. on my dvd rom drive. Please tell me how to copy the dvd . The dvd used for writing is from sonyDVD-R 4.7gb. and my dvd rom (combo drive) is from samsung with no region set. please help.
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
kjuvale is offline
Old 05-02-2006, 10:56 AM   #2 (permalink)
Traceur
zegulas's Avatar
Try making an image file of that DVD using Nero CD-DVD writing software.
If you don't know how to do that, then please let us know.
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 05-02-2006, 11:16 AM   #3 (permalink)
Default Re: how to copy Dvd to Hdd
I think u have scrached DVD.So go for vritual cd http://www.alcohol-soft.com download it and install.Then with the help of it u can copy the content to hard drive.And since ur relatives don't have DVD player u can go for Converting the DVD to VCD software www.yasasoft.com/magicdvdripper/ - 17k using it u can convert the DVD to VCD ......And burn to a cd...Any problem PM me or Reply........
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 05-02-2006, 11:40 AM   #4 (permalink)
Pharmaguru
kjuvale's Avatar
thanks for your replys I will try these. And the DVD is not scratched it is only 15 dyas old and plays well on DVD player and also on pc But i get error only copying to HDD. but thanks for sugessions.
kjuvale is offline
Old 05-02-2006, 12:45 PM   #5 (permalink)
If you have Nero 6 there is an option that you can directly write a DVD into VCD's,Nero will take care of all the troubles
rachitar is offline
Old 05-02-2006, 01:48 PM   #6 (permalink)
Netjunkie's Avatar
You may also want to look at this thread.
http://www.thinkdigit.com/forum/viewtopic.php?t=34372
Lots of methods out here. Just check it out.
Netjunkie is offline
Old 17-06-2007, 12:15 PM   #7 (permalink)
club_pranay's Avatar
well mate.. i got good news for you!
how about a programme that has..
Easy to use user interface , No complicated settings to worry about,
Rip a DVD movie in as little as one click of the mouse, Selectable output to VCD, XVCD, SVCD & XSVCD compliant files, Ripping of any program chain on the DVD, Selectable output to either a Bin/Cue image or Mpeg files, Automatic Chapter points in your (X)(S)VCD when outputting to a Bin/Cue Image, Fit a full movie on one CD-R in XVCD or XSVCD mode, Rip DVD files for conversion at a later time
and above all.. it's totaly free!! no water marks.. no trial versions.. not hidden money making tricks! just pure utility! trust me.. i've been using this tool for the last 4 years!!
http://www.eazyvcd.tk/
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
