Old 25-06-2004, 08:38 PM   #1 (permalink)
Default Folder Settings not being saved
I have a P4 2.60c GHz, Intel D865 GBF, 256 MB DDR RAM, 80 GB HDD and Windows XP Pro with SP1 based home system. My problem is that when I change the settings of a folder, they are not saved on shutdown and on restarting revert to the earlier settings. For example, if I change the way the icons in a folder are arranged (by date, size, etc.) or if I change from thumbnail view to "details" view then on shutdown none of these settings are saved and when I start the PC again the folder switches back to the previous settings. I have verified that the "Remember each folder's view setting" under Folder Options>View is checked. My user account has administrator rights.
abhijeet_ghosh is offline
Old 26-06-2004, 11:24 AM   #2 (permalink)
JAK
What the Heck !
JAK's Avatar
::::Start REGEDIT.EXE
Delete the followin
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ Shell \ BagMRU
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ Shell \ Bags
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ ShellNoRoam \ BagMRU
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ ShellNoRoam \ Bags
:::::Close REGEDIT.EXE
this shud reset all ur customisations(folder customisations).......
for further info see here..
http://www.windows-help.net/WindowsXP/troub-11.html
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 26-06-2004, 11:48 PM   #3 (permalink)
Thanks JAK, I will give it a try.
Old 27-06-2004, 12:06 AM   #4 (permalink)
JAK
What the Heck !
JAK's Avatar
Anytime.....m8..
JAK is offline
Old 18-08-2004, 08:43 PM   #5 (permalink)
it doesn't work!
rj2k is offline
Old 20-08-2004, 09:51 PM   #6 (permalink)
It worked for me. Thanks again JAK.
Old 21-08-2004, 12:08 AM   #7 (permalink)
still dosen't work!
rj2k is offline
