03-02-2006, 09:45 AM
how to write DVD to disc
Hi,
I have the vob files i need to write , but i dont have the ifo and bup files.
How do i create them . i could'nt do it with ifocreator it gave a error "no vob unit in vob file error ".i have cyberlink power producer .any other small soft that can do this ?
thanks in advance
03-02-2006, 07:57 PM
try dvd lab, its quite nice as it will not only make ifo but also offer u many more options. U will find it in DIGIT DVD.
Only for ifo files u can try ifoedit, but the smart act u have to do is first rename the vob file as VTS_00_01.VOB or something like this otherwise it gives some error
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
04-02-2006, 12:31 AM
use nero vision express it is the easiest with many options
04-02-2006, 09:16 AM
thanks a lot.i'll try that.
is nero vision bundled with nero 6.6 ultra or 7 ?
EDIT - guys , plz keep in mind that i use dial up
04-02-2006, 11:57 PM
yes nero vision is bundled with both nero 6.6 ultra and nero 7
05-02-2006, 12:21 AM
Re: how to write DVD to disc
Originally Posted by sagargv
Hi,
thanks in advance
IFOEDIT is small and free. Use "Author DVD" option.
-Keith
05-02-2006, 02:30 PM
thanks u guys , but sorry , it DIDNT work.
should i try renaming the file to something else ,
or is there any other soft ?
06-02-2006, 09:19 PM
c'mon guys , runnign out of HDD space .........
08-02-2006, 09:25 AM
nothings working . . . .
what do i do ?????????????????????????????/
system crashing , out of HDD Space . . .
Post any reply to save the system . . .
09-02-2006, 05:19 PM
OK . i am not trying to be funny.
i really need some help on this. if there's no small soft that can do it , i'll download from some place else. so PLZ suggest some authoring tool that doesnt ask for ifo and writes the vob "as is" without changing anything. ( coz the movies of what i have have a litle less Quality ex: lord of the rings - 1.7gigs ) .
thanks in advance
Search this Thread |
