Old 03-02-2006, 06:37 AM   #1 (permalink)
Live The Dream!
agnels's Avatar
Default Pc-cillin 2003 serial number to get Pc-Cillin IS 2005/2006
Can a Pc-cillin 2003 unused serial number (unregistered Serial Number) be used to get a full version of Pc-Cillin Internet Security 2005/2006
agnels is offline
Old 03-02-2006, 12:26 PM   #2 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
No. I think it cant be used.
PCcillin dont give lifetime upgrades.
Quiz_Master is offline
Old 03-02-2006, 01:52 PM   #3 (permalink)
18 Till I Die............
NO it can't be used. Why don't you use another free antivirus out there. There are many good free ones too. And if you wanna purchase one no one's stopping you .
mehulved is offline
Old 04-02-2006, 05:15 AM   #4 (permalink)
Live The Dream!
agnels's Avatar
Default You Can
Suprise Suprise
Trend Micro Pc-Cillin 2003 unused serial number can be used to get full version of Pc-Cillin Internet Security 2005 with 1 year free updates. Atleast I got it. I haven't tried with Pc-Cillin Internet Security 2006 because i dont have that version.
agnels is offline
Old 04-02-2006, 08:37 AM   #5 (permalink)
champ_rock
champ_rock's Avatar
I checked.... if u enter the 2005 serial no, in 2006 then it installs ......... takes the upgrade once and then somehow they detect it and it just says that the serial no. is invalid........
this trick can only be used to install the antivirus........and not get free upgrades..
Registered Linux user number 400618
champ_rock is offline
Old 15-02-2006, 05:59 AM   #6 (permalink)
Live The Dream!
agnels's Avatar
I dont think it can be called as a trick. They just allow it. Did you know that a Pc-cillin 2004 serial number can be used to upgrade to 2005. Maybe when 2007 comes 2005 number will be accepted to get Pc-Cillin Internet Security 2006
agnels is offline
