Old 02-02-2006, 11:31 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Adding some files ! ! !
While installing softwares v just custom install them ... & after few days some files r required 2 run certain tasks ...
tried from add/remove programs bt clicking on it (software name) just removes or uninstalls it from the system ...
My ? is how do u add these required files without re-installing the software ???
ax3 is offline
Old 02-02-2006, 12:13 PM   #2 (permalink)
slugger's Avatar
Me think u just need 2 pop in the concerned CD/DVD and in d custom option u just need 2 select only those options dat u now need 2 install, keeping the same path name as the original install. Since d existing filez do not coflict wid d new filez they won't b overwritten but the new filez will simply b added to d existing ones.
slugger is offline
