Old 26-10-2004, 11:45 PM   #1 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
Default Can somebody tell me what is the problem with my PC
i updated my Cyrix 667 to a New Intel Pentium 4 2.4 GHz with 256MB RAM and my system gives the blue screen error in XP and "a fatal exeption OE a has occured in 0028:FF0BF4A the system needs to be restarted" in Windows 98.. this problem usually occurs when i run any game e.g. "Need for speed Underground" or "Fifa any Version".. or in any game...
and also when i use the system for a long period of time like 2-4 hrs... my vendor has changed my RAM and Motherboard but still it happens... even they told me to see wether there is any software problem or not.. and i even got checked it with my freinds P4.. and those games were working perfectly from my Hardisk.... can anyone help me out of this please......
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 27-10-2004, 12:05 AM   #2 (permalink)
i am assuming u havent changed ur hdd .
- did u reformat and reinstall windows after installing the new motherboard with all its drivers ?
klinux is offline
Old 27-10-2004, 12:22 AM   #3 (permalink)
Laptoping
Sourabh's Avatar
Default lol
i feel its RAM RAM RAM RAM RAM!!
RAM dillema again !!
siince he has changed it n check i m not sure but i feel RAM is the culprit here
wait for other ppl to post
Sourabh is offline
Old 27-10-2004, 12:47 AM   #4 (permalink)
i reinstalled all 98 and Xp both with all its Drivers.......and about the i also changed to 128 Mb but still its the same..
Old 27-10-2004, 01:08 AM   #5 (permalink)
try these
- change the cmos battery . some batteries just drain while in storage .
- clear bios and choose optimal settings . check if hdd is set with lba option .
- run system on minimum . remove all devices which rnt important . eg cdrom drive , floppy , modem , network card etc and run the system and see . if it works well add each device one at a time and check to see if u get the errors
- switch the ide cables and run hdd from secondary . check ur hdd manufacteres site for disk manager and run the surface scan with their utilit . eg samsung has hutil and shdiag . check the utility for ur hdd and model .
- if u have the option check the cpu temperature . install 2 fans one in front(bottom) and one at rear(top) of the cabinet
- see if there is an update for ur bios in manufacturers site . keep this as last option only
- try as best to recreate the problem and isolate each device and software . will be tiresome process , but will really helpful in the end
klinux is offline
Old 27-10-2004, 07:10 AM   #6 (permalink)
The Photoshop Guy
cooljeba's Avatar
hmm.... may be IRQ conflict.....
see if any two devices are sharing the same IRQ ...
..:: peace::..
Jeba
cooljeba is offline
Old 27-10-2004, 08:10 AM   #7 (permalink)
u havn't mentioned whether u hav onboard vga?? any way IRQ conflict may b a reason but b sure 2 use latest mobo chipset and vga drivers. also check ur pc temperature after using it 4 2-3 hrs
Q : What\'s Flash ?
A : The fastest thing in the world.
Q : Who am I ?
A : The Quickest [flAsh]
[flAsh] is offline
Old 27-10-2004, 10:20 AM   #8 (permalink)
VD17's Avatar
ok.. this was anticipated...
anyway, I'M the "friend" on whose P4 he tested the HDD and the games. I had run the games right off his HDD without any problems... which prolly means that the HDD is not at fault. His vendor had changed the motherboard and RAM.. so its unlikely that the new RAM also has problems in it. Now as for the IRQ clashes, havent checked 'em out yet.
Yes, he has onboard VGA... Intel Extreme Graphics [motherboard is based on Intel 845GV chipset].
Vinayak
Dell XPS M1530: Intel C2D T5750, 4GB RAM, 250GB HDD, 256MB nVidia 8600GT GDDR3
Creative EP-630, Philips SHP 805.
VD17 is offline
Old 27-10-2004, 11:32 AM   #9 (permalink)
Medic on Call!!
medpal's Avatar
i think the sound card is the culprit here.
if its an onboard sound card and the card can not support the sound input of the game.
reinstall the drivers of the sound card (most likely smwdm.sys / .exe) i had the same problem with the sound cards and if i am not missing this problem was my first post in this forum.
so look for the hint on the error message may be it will indicate a file name.
also post your hijackthis log file for the experts here, who may help you.
medpal is offline
Old 28-10-2004, 11:03 PM   #10 (permalink)
VD17's Avatar
checked his sys again...
the memory ranges of the processor, Graphics system and soundcard do not match with the memory address given in the error....
Vinayak
VD17 is offline
Old 29-10-2004, 12:08 AM   #11 (permalink)
- if u have his m/b cd , uninstall and reinstall the devices .
- try this , if u disable onboard sound in m/b , boot , restart and reenable it , check if it works . if so just remove the devices giving the error from device manager and restart so that its all detected again .
- in the bios if u have an option "assign irq to vga" , try enabling it
klinux is offline
Old 29-10-2004, 02:08 AM   #12 (permalink)
Hanging, since 2004..
tarey_g's Avatar
change the brand of ram
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
