Old 01-02-2006, 02:41 PM   #1 (permalink)
Default system crashes
my system con celo 500 mhz 128 ram 40 hdd chipset board
810 main board once a day runing winxpsp 2 using hybernating when i hybrenate my machine and when i restart my machine resuming hybernating my os sudden shutdown then the day nither win98 or xp working i am format c: d: and try to installing os but xp gives me error pagr fault in no paged area and win98 hangs and give fatel error has oe occurerd i chage my ram with 3 other ram module but problem persists plese help me to solve my problem thank you
jojoji_jojo is offline
Old 01-02-2006, 09:14 PM   #2 (permalink)
yrana2002's Avatar
Do you get any blue screen crashes, clicking noises from the cabinet? If yes, post them here or post whatever you experience fairly. Alternatively, you can search the forum as this may be related to a problem with the Hard Disk
PS: Please use punctuations. It took me almost 10 minutes to understand what you meant.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 01-02-2006, 09:40 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
might be a problem with the bad sectors in the HDD
vijay_7287 is offline
Old 04-02-2006, 08:04 AM   #4 (permalink)
saiaspire
Posts: n/a
Default HDD
Try using a different HDD and post the results, also try running scandisk from another computer by connecting ur harddisk to it.
Old 04-02-2006, 08:15 AM   #5 (permalink)
It seems there is problem with motherboard, check using other motherboard or use ur hard disk and ram on other pc and see results
rajesh_nk22 is offline
