Old 30-01-2006, 09:04 PM   #1 (permalink)
Default DVD-RW or HDD
I have two computers , a notebook and a desktop.
I can buy either a Seagate 120GB Hard Disk with an External casing or a DVD-Rw with external Casing or the LG GSA-5163D (External DVD-RW http://www.cdfreaks.com/article/191).
What should i get ? :S ...
Will the transfer speeds be affected cos of the casing ?
Which is the best company for the DVD-RW ? I need to choose from these 5 if i get a normal DVD-RW+Casing -
Benq16X Dual Layer DVD Writer DW1640
SONY DRU-810A DVD Burner
Lite-On SHW-1635S
LG GSA-4167B
Lite-On 1963s
Please help me decide.
Also , if i use the external casing , do i require some sort of power supply ? :S
Thanks a lot ....
aksmohan is offline
Old 30-01-2006, 10:25 PM   #2 (permalink)
Also , if possible , please gimme thhe prices for the same ...
Thanks.
aksmohan is offline
Old 31-01-2006, 06:30 PM   #3 (permalink)
desertwind's Avatar
You dont have to bump it every hour. As far as mobility is concerned, buy an external laptop hdd (5k for 80 GB model) which is small enough to fit on your pocket.
If its for backing up only, DVD-RW will do. The best available is BenQ DW1640 and Sony DWQ30A
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 31-01-2006, 07:46 PM   #4 (permalink)
@aksmohan
No need to bump threads.If someone knows the answer he/she will reply.
Considering that you are new I hope you will read & follow the rules of this forum.
www.Oobertech.net
digen is offline
Old 31-01-2006, 09:12 PM   #5 (permalink)
abhishekkulkarni's Avatar
The one thing you should always keep in mind before purchasing any hardware product is - future utility .
Meaning , that an HDD would work very well for you as of now . But when the prices of Dual layered DVDs come down to say about 20-30 Rs in about an year's time , thats when you will yearn for a DVD Writer .
If you can write up to 8.5 GB of data on to a single disk then there is nothing like that . Also , an HDD can give up on you anytime , but for me a DVD has proved to be infinitely more durable .
So I would advise you to go for a DVD Writer . Personally speaking , I own a Sony DRU 810A DVD Writer and I am currently in " Storage Space Nirvana " .
As for the Internal / External casings that you have mentioned , I have no idea what they mean . Do you mean to say External DVD Writer / Internal DVD Writer ?
If yes , then I suppose that the transfer rates will be lower as compared to IDE / SCSI Drives due to the simple reason that the transfer rates of the Universal Serial Bus ( USB ) is much lower . This is presuming however , that the External Drive has a USB interface .
May the source be with you ..
abhishekkulkarni is offline
Old 31-01-2006, 09:39 PM   #6 (permalink)
Thanks for that.
How long does it take you to burn a single layer DVD on your Sony ?
I am talking about internal drives which can be used with a USB port with the casing(which converts IDE to USB)..
aksmohan is offline
Old 31-01-2006, 11:04 PM   #7 (permalink)
desertwind's Avatar
For me a It takes about 7-8 min to write a single layer DVD-R in 8x. Haven't tried it 16x as i havent a supporting media.
And, External USB casing (for both HDD and Optical drives) is very slow compare to the SATA interface. If you dont have a USB 2.0, the case will be even worser.
Old 31-01-2006, 11:12 PM   #8 (permalink)
which writer do u have ?
I do have USB 2 , but will get 16x on it ?
aksmohan is offline
Old 01-02-2006, 01:22 AM   #9 (permalink)
desertwind's Avatar
I own a Sony DWQ30A.
And i havent used external CD/DVD-RWs. But my external HDD is slower than the usual IDE interface.
Old 01-02-2006, 01:57 AM   #10 (permalink)
How's the quality of writing with that writer and is it quick ?
How much did u get it for ?
aksmohan is offline
Old 01-02-2006, 03:04 AM   #11 (permalink)
desertwind's Avatar
I posted it before. It finishes burning a single layer media in 7-8 minutes on 8x.
I got it for 3k
Old 01-02-2006, 08:46 PM   #12 (permalink)
I've decided to go for either a 5163 or a BenQ 1640/Sony 810 + External Casing.
Can someone tell me which case is best with the 2 drives and what speeds can i get ?
Also , If i cross-flash or wateva , do i get 16x ? Is it very risky (or has it been done b4) ?
aksmohan is offline
Old 01-02-2006, 09:55 PM   #13 (permalink)
i suggest BenQ dw 1640 but sony is also good but i still vote for Benq
Shwetanshu Srivastava
shwetanshu is offline
Old 01-02-2006, 10:52 PM   #14 (permalink)
Can u recommend an external casing too ?
aksmohan is offline
Old 02-02-2006, 07:45 AM   #15 (permalink)
nil_3's Avatar
Hope this happens!
Seriously, in India there is a flood of dual layered cheap movie DVDs manufactured in China/Taiwan. Then why the relatively cheap Dual layer DVD-Rs are not availabe in India. The one brand that is available in Kolkata costs Rs. 300/- a piece and the same situation is going on for the last one and half year. Prices of Dual layer writers are pocket-friendly now, blue-ray discs will be introduced shortly, but where is the pocket-friendly Dual-layer media?
By the way, whether the same situation prevails in other countries(USA/UK etc).
nil_3 is offline
Old 02-02-2006, 10:04 AM   #16 (permalink)
na i dont.. i alwayz buy stuff from Alsun Systems, Nehru Place.. they themselves provide the best stuff/ideas.. so i just go there and tell them wat i want.
Old 02-02-2006, 10:45 AM   #17 (permalink)
royal's Avatar
hey aksmohan ...
I think an external HDD would be easier to carry in case u want to take backup from other machimes 8)
Its just like a large pen drive, u see
royal is offline
Old 02-02-2006, 11:46 AM   #18 (permalink)
Ethan_Hunt's Avatar
Well apparently my friend happens to own the very same DVD Writer as Abhishek here and on a standard 4X speed of a Single layer DVD Burning takes up about 18 Minutes.At Around higher speeds though it was lesser time more like 8 Min(Or less) at 8X I suppose(Not completely sure of the speed).But overall the Sony DVD Writer is definetly a hot selling product in the market right now along with Lite-On and BenQ drives.
V for Vendetta
Ethan_Hunt is offline
Old 03-02-2006, 02:43 AM   #19 (permalink)
desertwind's Avatar
Hope this happens!
Ignorant ME!!!
I visited a local shop 2 days before to found that the cost of a Sony DL Media to be Rs. 90. Feeling overpriced, i settled down with some SL media (got it for Rs. 12 a piece). Only after that i realised that A Sony DL Media for Rs. 90 is a bargain. So I rushed into to shop very next day, but only find that they dont have any DL media priced less than Rs. 400.
Opertunity never knocks twice.
Old 03-02-2006, 07:02 AM   #20 (permalink)
Let the music play.....
djmykey's Avatar
@desertwind:- U learnt a lesson the hard way.
Btw I also am torn between in dilemma wether to buy a DVD-Writer or a HDD, hdd is safe, but I am not sure of DVD. Do they give up on us like CD's. I mean do their foil go off or something. Am asking this coz one of my fren told me that it does and thats y I stalled my purchase.
djmykey is offline
Old 03-02-2006, 09:23 PM   #21 (permalink)
A 4X Single layered DVD takes precisely 12 Min to burn . I haven't tried out an 8X one as of yet .
Thats because they are very costly in Pune , about 60 Rs per DVD .
Old 03-02-2006, 09:30 PM   #22 (permalink)
djmykey wrote -
No Mikey , an HDD is extremely volatile ...
Picture this situation -
You are going on your Unicorn with the HDD in your bag and you hit a big-bad-Pune-special bump .... And poof ! the HDD is dead as a dodo
Btw , the suspension of the Unicorn isn't bad though . Don't be mad at me
Old 04-02-2006, 07:14 AM   #23 (permalink)
djmykey's Avatar
I know this
Actually this is the question that I was looking for an answer. As of now I think there is moserbaer, sony and some 2-3 companies I think who retail DVD-R's but do their foil go off like it did with the CD's thats what I wanna know nothing else.
I know dood but the roads so suc seriously its too bad really for anyone riding a bike
djmykey is offline
Old 04-02-2006, 07:14 PM   #24 (permalink)
Isn't there like a tried and tested external case(USB)+drive(BenQ 1640 or Sony 810) combo which i can buy ?
aksmohan is offline
Old 05-02-2006, 12:06 AM   #25 (permalink)
Hey dude, I have tried many dvd witers like sony,gigabyte and tried many media like moser baer, optica, afa etc. However i find all dvds writen above 75% were faulty inspite of having the latest configuration using these dvd writers.
However when i lay my hands on Lite-on 1635s i was suprised.All dvds were written with out any fault. I used to get CRC error but every thing is fine now. Hence i prefer and suggest Liteon Dvd Writer.
Also read this months digit. Agent 001 Of DIGIT also suggest of Lite-On 1963s Dvd Writer. THIS IS MY PRACTICAL EXPERIENCE.
Also i suggest not to buy any optical drives from samsung. They tend to give many problems.Also the tray gets mis aligned very easily.
You can rely on me because i assemble and sell computers.
varungupta17 is offline
Old 05-02-2006, 12:53 AM   #26 (permalink)
I ain't buying a Samsung , that's for sure , but i just want to know a case+drive combo which has been tried and tested.
My drive options are -
BenQ DW1640
SONY DRU-810A
Lite-On SHW-1635S
LG GSA-4167B
Will buy my drive as soon as i'm sure the case and drive will work well.
aksmohan is offline
Old 13-02-2006, 11:27 PM   #27 (permalink)
Default DONT KNOW ABOUT CASING BUT LITEON IS THE BEST
BenQ DW1640
SONY DRU-810A
Lite-On SHW-1635S
LG GSA-4167B
Hi.Dude i m not sure about the casing but have heard that the casiing from "ENTER" company is good.
This is the case in bangalore where i stay.
About DVD Writer as i told u earlier Lite-On is the best.So there is no need to worry about it and u can safely buy it.
So if u need any assistance u can mail me at varungupta17@yahoo.com. or can post it here.
Also note that Liton Dvd Writer is available in many flavours:
1) Liteon 1635S.
2) Liteon 1963S.
Of the above Liteon 1963S is the best. However this model is not available in all cities. Hence check it in ur city. Price of both the models is SAME.
Old 15-02-2006, 12:27 PM   #28 (permalink)
@djmykey
it depends on why u need the xtra storage
i suggest u go 4 the HDD.coz it is much faster and much simpler to access the data (simple copy n paste )when compared to a disk where u hav to burn to disk to access it .moreover it is easy 2 handle a single drive than a dozen disks.
however,if its for storing/backin up movies/music ,i suggest u go for the DVD drive,coz in that case,u can also use the disks on a stand alone DVD player also.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 15-02-2006, 06:28 PM   #29 (permalink)
abhishek_sharma's Avatar
go in for a dvd writer whcih supports fireweire port, it offers much greater transfer speeds than usb
even if u dont have a firewire port on your comp...u can always buy one pci firewire card of tech-com or such companies for rs.300-450
on ebay.in they come for rs.300-475 with postage
also it is much better to burn 2 single layer dvds than buy an exoribantly priced dvd at present....u can also use a dvd rw, a 4x speed media frm moserbaer costs rs.90
abhishek_sharma is offline
Old 15-02-2006, 06:32 PM   #30 (permalink)
blacklight had written the above...
i would like to add that these days nero has got a nifty tool bundled with their burning software called InCd which allows you to format a CD RW or DVD RW and use it as a hard disk...i.e. u can simply copy paste, delete things in it like u do in a hard disk, thus it becomes relatively more hassle-free
