Ok, here's what your going to look for.
CPU: S939 AMD64
HSF: Get a Zalman all copper 7000
Mobo: Nforce4 Ultra (and if you can afford it SLi instead) Make sure it's the Nforce4 A03 revision chipset, Up until A02 there are problems with the PCI-e and 5x HTT
RAM: PC3200 Dual Channel kit, preferably 1024mb
HD: Seagate Baracuda 80GB sata w/ 8mb Cache
Case: (up to you, but make sure it's got good ventilation)
Power Supply: Enermax, Antec, Sparkle (whatever PS is available to you) 400 - 450 should be fine, dual fan preferable
Optical Drive: First 8x+-DVDRW, 2nd 16xDVDROM (2nd is optional)
Floppy: 3 1/2"
Video Card: Well if you have non SLi mobo, use a x600xt ATi radeon 0r 6600ut Nvidia, if you have a sli dual 6600ut Nvidia
NEW SYSTEM: http://i10.tinypic.com/4v4t75e.jpg
OLD SYSTEM: http://tinypic.com/kmgio
