Old 26-10-2004, 08:10 PM   #1 (permalink)
IG
Default ie error even when i dont use it...
i get this error even wheni dont use internet explorer.i use only firefox.i get this error as soon as yahoo messenger connects and then msn messenger doesnt connect at all.i keep getting another message: msn messenger cannot connect as internet explorer cannot connect to the internet".
the ie error is in this image:
what could be the problem.
also firefox does not open most pages at the first go.i use the latest release.
IG is offline
Old 26-10-2004, 11:03 PM   #2 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
install these things.......
ms .net framework 1.1 sp1
jre (go to java.com and download)
mas java vm (using windows update)...
restart ur system... set iexplore settings to default...
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 26-10-2004, 11:29 PM   #3 (permalink)
IG
um...i cannot use windows update.but nvm.thanks neways
IG is offline
Old 27-10-2004, 12:11 AM   #4 (permalink)
try these
- in explorer properties advanced tab , theres an option , disable script debugging . uncheck it if its checked
- in yahoo preferences there are options which ask u to log to the site or show some yahoo window as soon as u log in . yahoo companion i think . just browse the preference and change the settings to suit u
- for the msn error , see if u have ie in offline mode . check msn msngr's options too
klinux is offline
Old 27-10-2004, 12:44 AM   #5 (permalink)
Version 2.0
Deep's Avatar
I hope machine is not infacted by virus..
blaster ?
need system stats....
download stinger and scan the machine
http://vil.nai.com/vil/stinger/
or do online scan at trend micro site http://housecall.trendmicro.com/
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 27-10-2004, 03:44 PM   #6 (permalink)
Bewitched!
xenkatesh's Avatar
Scan ur pc completely with AV and find any spywares and torjans r located in ur pc!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 27-10-2004, 04:57 PM   #7 (permalink)
ice
Btw if ur gettin JRE, DO NOT get ms java vm.
Infact MS has discontinued its java VM and asked users to use the sun one.
ice
ice is offline
Old 27-10-2004, 04:58 PM   #8 (permalink)
IG
ie not in offline mode.problem was with firewall.everything works as soon as i disable it.will run scans once more.
thanks guys.
IG is offline
Old 27-10-2004, 10:21 PM   #9 (permalink)
which firewall app ?
klinux is offline
Old 27-10-2004, 10:24 PM   #10 (permalink)
Version 2.0
Deep's Avatar
check allowed ports in firewall..
btw which firewall ?
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 27-10-2004, 11:34 PM   #11 (permalink)
IG
zonealarm.latest one.
but same prob with sygate as well b4 zonealarm.
how do i check ports with these.
and btw which one is the best?
IG is offline
Old 28-10-2004, 12:00 AM   #12 (permalink)
Version 2.0
Deep's Avatar
hmm NAV 2005 ? sometimes internet worm protection also causes the problem...
and yes i hope windows firewall is not clashing with zone alarm and creating problems ?
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 28-10-2004, 12:00 AM   #13 (permalink)
forums.zonelabs.com , might help regarding port
i dont have zone right now , had trouble with ics.
using pccillin antivirus + firewall
klinux is offline
Old 28-10-2004, 12:08 AM   #14 (permalink)
IG
nope windows firewall not enabled.mine isnt even sp1 cos of some issues.
plus i use kaspersky av.not norton.
how good is pccillin?
IG is offline
Old 28-10-2004, 12:20 AM   #15 (permalink)
havent had trouble as yet with pccillin , it had good reviews in some mags , plus it uses way less system resources than norton . zone alarm is said to be flexible but only the pro version . i think zone alarm pro is given on trial basis , give it a shot
klinux is offline
Old 28-10-2004, 12:29 AM   #16 (permalink)
IG
ok.neways the problem has not surfaced today.ran ad aware and kaspersky scans and they found nothing.
dint install the jav and all that.
but no mo probs today.so i guess i'll leave it at this.
@klinux:will give it a shot.
thanks guys.
IG is offline
