Old 29-01-2006, 10:17 AM   #1 (permalink)
KoRn's Avatar
Default pc shuts down with dis warning everytime!!!!!
guys my pc displays a msg and says i have a minute to save all programs as the pc will shutdowon wat is wrong.....checkout the screenshots...
1.
2.[img=http://images3.pictiger.com/thumbs/7c/59dc4990243feeacab09130f20f7a37c.th.jpg]
3.
its one of these urls please checkout the screenshot i had to take using onscreen keyboard beacuse the shortcut in my keyboard doesnt work.
sum1 told me its a sasser but aster scanning with symantec sasser removal tool it detected nothing so please help........
BTW:i have insatlled the keyboard driver and software but still the shortcut screenshot button does not help wats wrong???
KoRn is offline
Old 29-01-2006, 10:59 AM   #2 (permalink)
Well! You can do the following thing.
Just type "shutdown-a" in run dialog box whenever you get such message.
Scan your system with any good AV
There is a very fine line between genius and insanity. I have erased this line.
freezer is offline
Old 29-01-2006, 02:03 PM   #3 (permalink)
KoRn's Avatar
u seee freezer my pc is like wackd up....i cant install anythng or even run a scan wit ms antispyware i cant do anything....sum guys say its my ram module so i calened it but still the same problem doesnt help please help.....
<<<*Liv3 F@sT Di3 FuN*>>>
<<H3@dB@nging My W@Y ThRoUGh LiF3>>
KoRn is offline
Old 29-01-2006, 02:16 PM   #4 (permalink)
Laptoping
Sourabh's Avatar
Or just install SP2
Sourabh is offline
Old 29-01-2006, 02:20 PM   #5 (permalink)
KoRn's Avatar
i have windows server 2000 and i cant even download beacause pc hangs and shutsown when i download sp4 so...sum say its msblast so iam am finding the fix in ms wait will kepp yall updated BTW will shutdown-a help is it safe
KoRn is offline
Old 29-01-2006, 04:45 PM   #6 (permalink)
__Virus__'s Avatar
shutdown -a will abort a shutdown so that u can dl the sp, disconnect the net, apply the sp, connect to net. restart the pc.
__Virus__ is offline
Old 29-01-2006, 06:04 PM   #7 (permalink)
KoRn's Avatar
ok i will try but sumtimes there i not even a warning that pc will shutdown it just shutsdown
KoRn is offline
Old 29-01-2006, 06:22 PM   #8 (permalink)
__Virus__'s Avatar
Thats strange i must say.
Old 29-01-2006, 08:57 PM   #9 (permalink)
choudang's Avatar
your pics are not clear to me.. so i just make a guess tat a msg has come with some lines and "Your computer wil shoutdown after <seconds>"
Your Pc has been infected with a Bluster Worm.... i forgot the name... best suggesion is that download Bluster Worm remover tool from Norton website or run a decent antivirus like Kaspersky with latest update..
For every action, there is an equal and opposite criticism.
choudang is offline
Old 30-01-2006, 01:00 AM   #10 (permalink)
Indian by heart
planetcall's Avatar
Lol......post new pic. Bigger and clear one.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
planetcall is offline
Old 30-01-2006, 02:30 AM   #11 (permalink)
SignificantMind
Posts: n/a
hmmm well this is due to the worm called blaster or sasser(i cant remeber the name of it) it cuts you out from the internet after 60sec window terminating you need to go on the other computer and download a good antivirus program. I had this worm before and got rid of it. Rember when ever you try connecting to the internet through internet explorer or messenger or anything that does connects to the internet activates the worm application for to shut down.
Old 30-01-2006, 04:07 AM   #12 (permalink)
siriusb's Avatar
Yea, it's my favourite blaster worm. Follow these instructions in here symantec.com
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 30-01-2006, 05:10 PM   #13 (permalink)
Indian by heart
planetcall's Avatar
if its blaster then it would state that there is some error in RPC as it happened with me. I created a simple naughty application to annoy my friends. You can download it from the project page of abhishekclub. It is not a virus and causes no harm . Its an XP prank but do use it wisely and I owe no responsibilities.
Old 30-01-2006, 06:51 PM   #14 (permalink)
i even downloaded sasser and blaster removers from symantec they didnt detect anything so wats da problem!!! and BTW shutdown-a doesnt help solve the problem run cannot find the filename cummon guys please help me
BLINK182 is offline
Old 30-01-2006, 06:54 PM   #15 (permalink)
KoRn's Avatar
sorry guys posted in using my cuzins id its my problem
KoRn is offline
Old 30-01-2006, 07:05 PM   #16 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
There is a gap between shutdown and -a.
Its shutdown -a not shutdown-a
PS: Pls post a clear and BIG screenshot, so that we can rectify the problem easily! I could hardly see in the image that the Shutdown dialog box is pointing towards some application in C:\WinNT folder that has caused some problem! So pls post a better screenshot...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-01-2006, 07:08 PM   #17 (permalink)
Laptoping
Sourabh's Avatar
KoRn, make sure you dont post from multiple ids. It is quite misleading on the forums. Hope you get the point and such a thing is not repeated
Sourabh is offline
Old 30-01-2006, 10:49 PM   #18 (permalink)
::cyborg::'s Avatar
same problem was with me there is a file called lsass.exe which initiates the shut down process and the dialog ehich occurs that ur system is shutting down is also
the reason is only only only only the
SPYWARE
download spyware doctor from www.pctools.com
::cyborg:: is offline
Old 31-01-2006, 04:40 AM   #19 (permalink)
__Virus__'s Avatar
plzzzzzzzzzzzzzzz do let us know if u installed sp2 and all the updatesssssssssssssss. that will sureshot solve the isssue man its as simple as that
Old 31-01-2006, 12:32 PM   #20 (permalink)
::cyborg::'s Avatar
hey man tell me ur prob solved or not
Old 31-01-2006, 03:50 PM   #21 (permalink)
quickest solution , i feel is to reinstall XP .Immediately use AV.
If u have files on that drive where XP is, try to get someone elses HDD and do it.
EDIT : Before trying the above method first
And can u try the same in the safe mode < tap f8 while startup > .also try a system restore to a date when system was working fine. and dont foreget to DO AV CHECK
sagargv is offline
Old 31-01-2006, 06:10 PM   #22 (permalink)
KoRn's Avatar
when will u guys understand the problem!!!!!!!!!i have windows server 2000,i downloaded sp4 but it still dowloads automatic additions after installation so the downloads are hell long and pc shutsdown and if i run a scan with ms antipsyware pc shuts down without warning .....so ill download spydoc and tell u guys ok thanx anyways
KoRn is offline
Old 31-01-2006, 06:11 PM   #23 (permalink)
KoRn's Avatar
sure dude sorry about that problem
KoRn is offline
Old 31-01-2006, 06:20 PM   #24 (permalink)
KoRn's Avatar
This is the screenshot in the "TYPED" way lol i think the BLINd guys may be able to read the msg now.jus joking.
"the system process
C://WINDOWS NT/SYSTEM 32/lsass.exe terminated
unexpectedly with this status code
-1073741819 The system will now shutdown and restart"
KoRn is offline
Old 31-01-2006, 06:22 PM   #25 (permalink)
KoRn's Avatar
SPYWARE
yup its lsasss
KoRn is offline
Old 31-01-2006, 10:03 PM   #26 (permalink)
::cyborg::'s Avatar
then korn the reason is only spyware now start in safe mode and scan with spware doctor ur system will not shut down
Old 01-02-2006, 07:58 AM   #27 (permalink)
KoRn's Avatar
ok will try because i ran in normal mode and pc just shuts down like when i scan wit ms antispyware
KoRn is offline
Old 01-02-2006, 08:57 AM   #28 (permalink)
KoRn's Avatar
Default NOPE
hey cyborg i scanned using spydoc in safe mode but pc just shutsdown wat do i do??
BTW some people said it was because my ram module was dusty so i cleaned it with a thin cloth but problem persists..since i have 256 ram shud i remove the 128 mb ram and then try out which ram module is damaged.it maybe beacuse one of the ram modules are damaged...........
ill first wait for a reply from u guys then ill do it ok..... 8)
KoRn is offline
Old 01-02-2006, 10:56 AM   #29 (permalink)
::cyborg::'s Avatar
yes a ram module can also do that first i want to know that ur system was suffering from frequent shutdown before this prob do tell me i will solve prob brother
bcoz i know the frustration
Old 01-02-2006, 03:25 PM   #30 (permalink)
i ran the scan wit spydoctor in safe mode but pc still shuts down without warning wats so wrong wit my comp??its all skrewed up and i want a solution desperately please solve my prob.however i wont be able to remove one ram module 2day only on sundays im free so ill do it den,meanwhile tell me wat i shud do now....the pc shuts down when scan reaches 70% or so.......
BTW yes my pc was suffering from frequent shutdowns before dis lsasss thing so???
please help me cyborg...
BLINK182 is offline
