In case of airtel, they give you a static ip for any plan if you pay some extra amount (forgot how much). Check the cust support as my this info is a bit outdated.
In case of tata indicom boradband, u get static IP for free on each router based connection.
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
I just checked the Tataindicom website & this is what it says...
What are the charges for getting additional Static IPs?
With every Router connection 1 Static IP is provided free. If you wish to avail additional Static Ips you will be charged Rs 2,000/- (service tax extra) per annum per static IP.
Ahh a static ip indeed would save the dynamic configuration hassle.Does anyone know how much does Airtel charge for a static IP?
www.Oobertech.net
