Old 26-01-2006, 09:34 PM   #1 (permalink)
Default January 2006 Digit CD - Displaying Black Screen
Hi
When I am inserting January 06 Digit CD, the entire motnitor becoming black and "It's readers" is showing in big letters with a big square. I tested this CD in other PCs. In other PCs, this CD is working and promtply showing "Digit greetings to it's readers 2006" with light/flowers. and it is not moving further and no indications also.
Why this CD is showing in my PC. I am using Combo (DVD/CD writer)
Other CDs are working perfectly. My RAM is DDR 512MB with 256 AGP Card. Assu mother board and AMD 2600+ processor
How to overcome this problem.
Bye
TVB RAJU
TVB RAJU is offline
Old 26-01-2006, 10:11 PM   #2 (permalink)
Technoholik !!
Tech&ME's Avatar
Default Re: January 2006 Digit CD - Displaying Black Screen
Originally Posted by TVB RAJU
Hi
Bye
TVB RAJU
Install a CD-ROM drive in your comp and try to run it instead.
Why ? Most Combo drives fails to read CDs properly.
U can also install the flash player 8 from the DVD to enable the CD to run properly.
Tech&ME is offline
Old 27-01-2006, 06:33 PM   #3 (permalink)
phatratt's Avatar
^^^its not the combo drive's fault,infact i tried the cd on a cd-rom and showed the same stuff.LAter intalled the latest flashplayer and the problem is solved!!
phatratt is offline
Old 16-02-2006, 07:08 PM   #4 (permalink)
mohanty1942's Avatar
Locate a digit CD which has a folder named Code. Get flashinstaller from that folder. It will enable you to display all screens correctly.
No Terms : Just One Condition
mohanty1942 is offline
