Old 26-01-2006, 11:24 AM   #1 (permalink)
Default shortcut key...
hi,
i invariably use the feature "show hidden icons/folders" (not that u may assume of! :d ) how can i create a shorcut key for triggering this option on or off? like ctrl+alt+u or something like that... is it possible?
/legolas
legolas is offline
Old 26-01-2006, 02:23 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open Notepad and paste following lines:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
"Hidden"=dword:00000002
Save it with any name and with the extension .reg, like "Hide.reg"
Similarly again create a new file and paste following code:
"Hidden"=dword:00000001
Now save it with any name and extension .reg, like "Unhide.reg"
Now what u hv to do, when u want to hide files/folders, double-click on Hide.reg file and in case u want to unhide, simply double-click on unhide.reg file
Regarding to shortcut keys, u can create their shortcuts and can assign shortcut keys by going to its properties!!!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-01-2006, 03:32 PM   #3 (permalink)
nothing happened, after i clicked the hide and unhide . reg files....
/legolas
legolas is offline
Old 30-01-2006, 03:36 PM   #4 (permalink)
__Virus__'s Avatar
U need to logoff as I tested it
__Virus__ is offline
Old 30-01-2006, 03:47 PM   #5 (permalink)
Microsoft MVP
U hv to refresh the window after applying this reg tweak!
Its working fine for me!
PS: If u hv enabled Hide extensions for known filetypes, then disable it in Folder Options. Then u'll be able to see whether the reg file u hv created hv .REG extension or .REG.TXT extension. If it has .REG.TXT extension, then change it to only .REG extension.
Old 30-01-2006, 09:11 PM   #6 (permalink)
yrana2002's Avatar
When you double click on either files, it will ask you:
Do you want to add this to the registry
Just click yes. Similarly for the Unhide key.
Maybe, if you click Hide first, it wont display anything because its already there by default. :roll:
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
