Old 26-01-2006, 07:52 AM   #1 (permalink)
Gracias Senor
dreams's Avatar
Default Merging Partitions - HELP !!!!
Hello all..
I need a quick help.. I have alloc 5GB for C Drive (Windows).. But this is not enough and so my sys hangs a lot.. I hv another Partition of 5 GB and i like to merge the 2 Partitions and make it to 10 GB.. I think then the sys runs fast.. cos i use Adobe PS and it takes a lot of time to load and make my sys very slow..
So i need to knw wats the best way to do this.. and also i dont want to didturb my OS.. No re-installing OS again..
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 26-01-2006, 10:42 AM   #2 (permalink)
PARTITION MAGIC is the best solution for your query.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 27-01-2006, 06:25 PM   #3 (permalink)
phatratt's Avatar
Mearging two partiton won't gain much speed.make sure u have kept the root drive(C clean coz dumping too much files or installing lots of software can cause the os to slow down.Remember to keep the C: free with atleast 1-1.7GB of free space.If u want to mearge the partition then the best bet is Partition magic.
phatratt is offline
Old 28-01-2006, 12:58 AM   #4 (permalink)
no merge partition will help. U should install the Adobe PS CS in a differnet partition and msot importantly the temp files dir in a diff partition, same goes with a dedicated swap twice ur RAM size
Techie_Geek is offline
Old 28-01-2006, 07:08 AM   #5 (permalink)
sujithtom's Avatar
If you shell out enough money try Partition Magic or try that free tool Digit provided (forgot the name)
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 28-01-2006, 07:54 AM   #6 (permalink)
Gracias Senor
dreams's Avatar
Can v change the temp files dir of Photoshop ??
dreams is offline
Old 29-01-2006, 07:56 AM   #7 (permalink)
Gracias Senor
dreams's Avatar
Hi guys.. Now i have Partition Magic and tried to Merge my 2 Drives.. But i read the Help doc in Partition Magic and it says
"DO NOT MERGE A PARTITION IF IT HAS A OS INSTALLED IN IT".
But i have to Merge my Windows drive and its adjacent drive.. Now how shuld i do it.. Need step by step process..
TIA
dreams is offline
Old 29-01-2006, 12:13 PM   #8 (permalink)
sujithtom's Avatar
Just follow the usual method but there is a risk of losing ur OS
Old 29-01-2006, 12:34 PM   #9 (permalink)
Gracias Senor
dreams's Avatar
No way i shuld Lose my OS.. Any other way like takin a Back up and then Merging ??
dreams is offline
