Old 26-01-2006, 01:47 AM   #1 (permalink)
Technoholik !!
Tech&ME's Avatar
Default Visual Basic 6 Enterprise Edition and Combo box
Dear friends,
Can anyone tell me how can we make the data fields from a database appear in the Combo Box drop-down list at run time.
So, what i mean to say is, I want the entries in the Combo Box Drop Down list to be taken by VB from a ACCESS DATABASE TABLE directly at run time.
Please help me solve this problem.
I have tried several way to do this, and I am able to display the field data from the database but only the first record is shown, all other records are not shown at run time.
Please help
Tech&ME is offline
Old 26-01-2006, 11:25 AM   #2 (permalink)
rajesh's Avatar
Try giving the Code u r using. We might be able to help.
Are you navigating through the recordset ?
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
Old 26-01-2006, 12:32 PM   #3 (permalink)
siriusb's Avatar
You may want to see if this suits you:
http://www.experts-exchange.com/Prog..._20814474.html
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 26-01-2006, 07:37 PM   #4 (permalink)
Technoholik !!
Tech&ME's Avatar
Well! u forgot to mention that the site you are referencing to is a PAID site. So, in order to view the solution one has to sell out atleast $9.95 ?
Could you please post the solution instead! (directly here)
Tech&ME is offline
Old 26-01-2006, 10:49 PM   #5 (permalink)
siriusb's Avatar
^Did u scroll down at all? I am not a member but I can see the solution no problem.
siriusb is offline
Old 27-01-2006, 05:02 PM   #6 (permalink)
Technoholik !!
Tech&ME's Avatar
Thanxs, problem was solved.
I modified the code as per my requirement and it works fine now.
Tech&ME is offline
