Old 26-10-2004, 01:19 AM   #1 (permalink)
Default One strange problem
Hi there,
I m facing one very strange prob(Strange coz never seen that before)
I m having one DVD ROM, and one CDRW drive both of sumsung.,
now i don't get them on DOS when booting from any bootable.
It says No driver found in the time of installing CDROM,
and in last it says No genric CDROM found,
Help me as soon as possible.
I'll Thanx u later (No thanx in advanced :roll: :roll: )
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 26-10-2004, 11:22 AM   #2 (permalink)
ASH_DSG
Posts: n/a
Default YOUR PROBLEM CD/DVD ROM
HI,
CAN U TEEL ME WHAT IS UR MOTHERBOARD AND PROCESSOR.
IS IT ATX. AND IF U CHECK UR BIOS DOES IT DETECTS UR CD/DVDROM.
IF YES AND U HAVE MAKE THEM FIRST BOOTAVLE DEVICE BEFORE HDD.
IF IT IS ALL OK. THAN CHECK UR CD IS IT BOOTABLE ON OTHER SYSTEMS.
OK.
BYE.
Old 27-10-2004, 11:30 PM   #3 (permalink)
hey this is the main prob
BIOS detect them, can access them in my OS,
but can't get them in DOS
Old 27-10-2004, 11:46 PM   #4 (permalink)
do u have the *.sys device driver for ur cdrom and the proper entries in autoexec.bat and config.sys ?
try this
http://www.samsung.com/au/products/o...0000013359.htm
If u have the .sys file check if u have the proper settings .
http://www.samsung.com/au/products/o...0000013369.htm
remove the REM from the autoexec.bat and config.sys .
klinux is offline
Old 28-10-2004, 11:35 PM   #5 (permalink)
Hey thanx dude but the driver i already know but it isn't working,
These two i have tried it out then i have asked here,
Thanx for helping me but pls help me again???????
One more thing
can we have data back from internally short HDD.
Old 28-10-2004, 11:45 PM   #6 (permalink)
- could u post the autoexec.bat and config.sys lines u have right now here ?
- does it work in dos if u have any one drive at a time ?
- if ur hdd pcb is gone , data might still be ok and recoverable if u get it to the few service centers available who can switch the pcb with identical working one . would cost u though
- which order have u connected the drives in which is primary/secondary etc
- try choosing cable select on optical drives , if that fails , set one as master and slave with the jumpers
klinux is offline
Old 30-10-2004, 01:58 PM   #7 (permalink)
Here is this
I have tried to boot from Both my ODD's,
They let me boot but when in DOS they search for ODD in first step,
This is message "No Drives found",
as far as Autoexec.bat & Config.sys,
I'll send it in night from home
in college this time.
Gave my HDD for replacement,
coz pcb replacement would remove the warrenty,
nothing s importent to recover for money,
Only movies(50-70) round.
