Old 23-01-2006, 01:48 PM   #1 (permalink)
chitvan's Avatar
Default how can i change colour in ms-dos ?
how can i change color of text & background in ms-dos in winxp sp2?
i want to change text color white to bright green.
chitvan is offline
Old 23-01-2006, 02:18 PM   #2 (permalink)
yrana2002's Avatar
Open ms-dos
And type:
Color 2
For other colors:
0 = Black
1 = Blue
2 = Green
3 = Aqua
4 = Red
5 = Purple
6 = Yellow
7 = White
8 = Gray
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 23-01-2006, 04:44 PM   #3 (permalink)
18 Till I Die............
u can also right click on the the dos window in taskbar and click on properties, you can change the colour from there
http://www.bash.org/?258908
mehulved is offline
Old 30-01-2006, 03:58 PM   #4 (permalink)
chitvan's Avatar
thanx
chitvan is offline
Old 29-06-2006, 12:14 AM   #5 (permalink)
shovik's Avatar
Default Re: how can i change colour in ms-dos ?
You can also do combinations of two colors for both text and background.
The syntax is as follows:
Sets the default console foreground and background colors.
COLOR [attr]
attr Specifies color attribute of console output
Color attributes are specified by TWO hex digits -- the first corresponds to the background; the second the foreground. Each digit can be any of the below values.
0 = Black 8 = Gray
1 = Blue 9 = Light Blue
2 = Green A = Light Green
3 = Aqua B = Light Aqua
4 = Red C = Light Red
5 = Purple D = Light Purple
6 = Yellow E = Light Yellow
7 = White F = Bright White
If no argument is given, this command restores the color to what it was when CMD.EXE started. This value either comes from the current console window, the /T command line switch or from the DefaultColor registry value.
The COLOR command sets ERRORLEVEL to 1 if an attempt is made to execute the COLOR command with a foreground and background color that are the same.
Regards,
Shovik.
shovik is offline
Old 29-06-2006, 12:52 PM   #6 (permalink)
JGuru's Avatar
You can also change color through C programming!! For normal users create a link to 'DOS Console' in the
dekstop, and click on 'Properties' .There you can change all the options like memory, foreground color,
backgrounf color etc.,
JGuru is offline
