Old 25-10-2004, 04:37 PM   #1 (permalink)
Default DVD To CD
Sir
i want know that which is the best software which can be used to RIP a DVD to a single CD(700MB) or an avi file.The software should not requires any user intervention once the conversion process starts.And if it also do not requires any free space then it will be a added feature.The codec used can be any of Xvid or DivX.
Thanks in Advance
Mohit
mohitmoudgil is offline
Old 25-10-2004, 05:21 PM   #2 (permalink)
http://www.thinkdigit.com/forum/viewtopic.php?t=5338
http://www.thinkdigit.com/forum/viewtopic.php?t=3102
http://www.thinkdigit.com/forum/viewtopic.php?t=5929
there are more
im just tired of searchign and posting
mods
No Mercy, No Limits.
theraven is offline
Old 25-10-2004, 07:58 PM   #3 (permalink)
Hi mohitmoudgil, welcome to the Digit Community!
First of all make sure that you are well acquainted with the forum rules.
And heres a tip: Please try to use the Search feature before starting a new topic. This way it would save all of us a lot of trouble, including yourself. And it also helps to keep the forum clean.
Regards,
PS: Btw, thanks for the heads up theraven, and sorry for takin all the trouble
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
