m trying to install it frommy HDD, the error is follows....
CRC error: The file D:\Rockstar Games\Max Payne 2\MP2_Levels_A.ras does not match the file in the setup's .cab file. The medium from which you are running the setup may be corrupted; contact youe software vendor
*: If my CD is damaged, i won't be able to copied all the files to my HDD.
*: if my cd-rom is faulty, how ome it reads other files without prob.
*. i have installed from same media on last November, that was a clean one.
i have a question: How can we extract the contents of a Setup file? like nVidia setup, you can extract the files to HDD.
