Old 19-01-2006, 05:14 PM   #1 (permalink)
Default Do i need to install Fonts
Dear Brother,
i use Adobe Photoshop 7. Recently I got a more than 200 new types of fonts. But my Harddisk has only a little free space.
Can i use those new fonts without installing it in Windows\Font Folder.
Thank you in advance
sm_ashiq is offline
Old 19-01-2006, 06:51 PM   #2 (permalink)
yrana2002's Avatar
I would suggest you keep as minimum fonts as possible, onlt those that u use frequently or those which you think you may use in future.
Too many fonts cramps up the system, resulting in very slow startups & other system processes.
PS: Do not remove fonts necessary for your Operating System. Removing these can result in serious system errors.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 19-01-2006, 09:55 PM   #3 (permalink)
9437077259
go4saket's Avatar
Are you sure that the overall system performance is effected if one has many fonts installed. I have about 500 Fonts installed...
go4saket is offline
Old 19-01-2006, 10:52 PM   #4 (permalink)
^^ See http://graphicssoft.about.com/od/abo...ntoverload.htm where they discuss problems in Win 9x machines caused by having too many fonts. This apparently is not so severe in Win2k and WinXP systems...
@sm_ashiq, you should consider cleaning up your main partition (C: usually) as clutter in this drive will affect performance. Second, you should move data files away from this partition and into a separate partition... Third, if the entire Harddisk is running out of space, you should consider purchasing additional software... Finally, in the link I have provided in the beginning of the post, there is info on managing fonts - software available etc. Use it to remove unnecessary fonts and then add only fonts that you need...
Arun
sakumar79 is offline
Old 19-01-2006, 11:19 PM   #5 (permalink)
too many fonts definitely means very very slow startup and a slower system performance
u can test the fonts using font viewers an dload the selected chosen fonts to ur windows fonts dir
i once installed corel draw 10 and about 500 fonts with it.
the next day i had to uninstall the software, to cntinue wrking
Techie_Geek is offline
Old 20-01-2006, 12:30 AM   #6 (permalink)
choudang's Avatar
i don't know that too many fonts can slow up the pc or startup...... cuz i have 2500+ fonts installed with Corel 12 and PS CS2. till now i didn't face any prob.
may be @Techie.. you have faced other prob.
For every action, there is an equal and opposite criticism.
choudang is offline
