Originally Posted by wthongni
Hi!
can anyone tell me why I get the following errors
Fatal error: Call to undefined function mysql_connect() in C:\Program Files\Apache Group\Apache2\htdocs\db.php on line 7
I am using:
1. Apache 2
2. PHP5
3. Mysql 5.0
I have tried to uncomment the extention_dir in php.ini for php_mysql.dll.
What more should I do?
Please Help!!
:roll:
In PHP 5, MySQL is no longer enabled by default, so the php_mysql.dll DLL must be enabled inside of php.ini. Also, PHP needs access to the MySQL client library. A file named libmysql.dll is included in the Windows PHP distribution and in order for PHP to talk to MySQL this file needs to be available to the Windows systems PATH. See
http://www.php.net/manual/en/faq.ins...tion.addtopath for information on how to do this. Although copying libmysql.dll to the Windows system directory also works (because the system directory is by default in the system's PATH), it's not recommended.
As with enabling any PHP extension (such as php_mysql.dll), the PHP directive extension_dir should be set to the directory where the PHP extensions are located. See also the
Manual Windows Installation Instructions. An example extension_dir value for PHP 5 is c:\php\ext
Note: If when starting the web server an error similar to the following occurs: "Unable to load dynamic library './php_mysql.dll'", this is because php_mysql.dll and/or libmysql.dll cannot be found by the system.
Hope it solves your problem
Regards,
