Old 19-01-2006, 11:01 AM   #1 (permalink)
linardni's Avatar
Default PC doesn’t start..Help!!!
I formatted my PC and installed Win98. But when I upgraded it to XP the machine doesn’t start. It shows the following message. Plz help with step by step instructions.
A problem has been detected and Windows has been shut down to prevent damage to your computer.
BAD_SYSTEM_CONFIG_INFO
If this is the first time you’ve seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to Select Advanced Startup Options, and then select Safe Mode.
Technical Information:
***STOP: 0x00000074 (0x00000003, 0x00000002, 0x80087000, 0xC000014C)
linardni is offline
Old 19-01-2006, 04:08 PM   #2 (permalink)
slugger's Avatar
try and check ur RAM
slugger is offline
Old 19-01-2006, 05:09 PM   #3 (permalink)
::cyborg::'s Avatar
if ur bios has a option for fast boot enable that for a test then check ur ram checksum & also clean the ram and the slot & again insert it
::cyborg:: is offline
Old 19-01-2006, 10:12 PM   #4 (permalink)
phatratt's Avatar
Please give uo your Pc configuration.Make sure it meets the minimum requirements for installing WinXP.
phatratt is offline
Old 19-01-2006, 10:17 PM   #5 (permalink)
Go to this link
http://support.microsoft.com/?kbid=326679
tanmoy_rajguru2005 is offline
Old 19-01-2006, 11:38 PM   #6 (permalink)
check ur RAM, smtimes a fresh WIn Xp install helps
Anyhw upgrading frm Win 9X to NT is not advisable
u can hwever upgrade in same platform
Win 9x [Win '98 to Win Me]
Win NT [Win 2K to Win Xp]
Techie_Geek is offline
