Old 19-01-2006, 03:10 AM   #1 (permalink)
Default HELP ME 2 GET IT DONE
hi
This is my first Post
friends how are all, am fine
coming to point
Dear frinds i want to download all queries & replies
from starting 2 ending,bcoz i want download all queries &
convert them all into pdf files. I get hardly 2 hours 2 spend
with internet i tried 2 downl one-by-one but it took long time
2 downL, means for 1 page of 20 queries nearly 1.5 hours,
is there any link 2 downL all in one go, no problem whatever
time it takes by gods grace i have b.band connection,and using opera
explorer
this is all why bcoz i get lot of time at my office in the
front of computer once i downL all queries i can read one-by-one
at my office,and i can read all everydays queries at my home.
plz show me a way or any link to do that.
thx in advance,
pls comment me about above furnished query
is it easy to understand you all or do i need 2 make any
change in my english your comments will defnitely change my life.
thx once again.
regards
jnreddy
jnreddy is offline
Old 20-01-2006, 12:04 AM   #2 (permalink)
dear
it's rather better to use the search feature and try to solve the particular problem one's facing. because achieving the whole lot is useless because many solutions are specific and not general.So it won't help u in that case
Techie_Geek is offline
Old 20-01-2006, 11:07 AM   #3 (permalink)
Use Adobe acrobat professional in file menu select create and in create select webpage
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 20-01-2006, 05:11 PM   #4 (permalink)
KoRn's Avatar
dats a hell lotta of a download.anyway if u wanna download then use adobe acrobat and in the file menu click create and then webpage then follow the instructions its easy.
BTW dats kinda wierd cuz u can search and get them all instead of wastinf time and space!anyway dats how u like it so all da best reddy.
<<<*Liv3 F@sT Di3 FuN*>>>
<<H3@dB@nging My W@Y ThRoUGh LiF3>>
KoRn is offline
