24-10-2004, 05:17 PM
How can the badsectors get removed from harddisk
How can the badsectors get removed from harddisk? I have one 4.3 GB harddisk which contains some badsector. So Is there any software to remove the badsectors
Navaneeth
My Phones: Motorola T180, Nokia 2600, SE J300i, SE W810i
24-10-2004, 05:39 PM
The Photoshop Guy
Bad sectors can't be removed......
try nortorn disk doctor can hide up the bad sectors from the OS.
..:: peace ::..
Jeba
24-10-2004, 06:11 PM
da' Ťurntable ruleth
yaa as jeba said they cant be removed
A portion of a disk that cannot be used because it is flawed. When you format a disk, the operating system identifies any bad sectors on the disk and marks them so they will not be used. If a sector that already contains data becomes damaged, you will need special software to recover the data.
It’s not unusual for a hard disk to leave the manufacturing process with a damaged sector; however, this does not affect the overall performance of the disk as the damaged space is considered unusable.
so all i can say use the HDD as long as it lives
but back up often rather daily
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
25-10-2004, 12:35 AM
Coming back to life ..
Hmm Try using SpinRite ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
25-10-2004, 12:46 AM
Now this is a very crude method of dealing with the problem. remember one thing - the more u ask ur HD to read bad sectors and attempt to write or recover, the more chances are that ur HD will crash. SO when u find that some files are curropt dont delete them. let them be there. atleast now u have marked the sectors which are screwed.
and if it eventually crashes...u can try inverting it and tapping it lightly with a screwdriver...temporarily rejuvenates HD in many cases, but thats it. beyond this point, no options.
25-10-2004, 01:16 AM
bad sectors can not be removed they can be masked by running Scandisk in Thoroug option
http://swatrant.blogspot.com/
25-10-2004, 01:28 AM
Eh? What are all you guys talking about ? Bad sectors CAN be removed, provided that the bad sector was caused due to logical errors and not physical damage.
Spinrite can locate and remove such logical bad sectors (caused by filesystem errors or due to flux domain neutralization), and if there are physical bad sectors, it can attempt to recover data from the bad sector and relocate the data. Plus it can also find weak areas that might fail in the future, and it also refreshes the magnetic media so that the data lasts longer.
I suggest you give SpinRite a try. The latest version is 6, which can work on any filesystem including NTFS and RAID.
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
25-10-2004, 01:01 PM
Thanks Dexter, I will try with Spinrite
Navaneeth
26-10-2004, 07:26 AM
The Photoshop Guy
dexy we were talking abt the physical bad sectors.... and logical bad sectors will be easily removed by NDD.
..:: peace ::..
Jeba
26-10-2004, 12:15 PM
the guy doesnt mention anything about the cause for bad sectors. So just writing him off for bad sectors assuming it to be physical badsectors is not right. Also NDD isnt nearly as effective as spinrite and NDD doesnt attempt to relocate data from physical badsectors like spinrite does mate
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
26-10-2004, 02:29 PM
Re: How can the badsectors get removed from harddisk
Use the s/w Norton Disk Doctor, it will help you to remove / it will make the bad sector unused...
26-10-2004, 03:49 PM
Thanx deXter, me too wanted some kinda answer to this problem
Walk on the Wild Side. The other side SUX!!!
26-10-2004, 08:20 PM
couldn't find spinrite trial, can any one upload it, please
Navaneeth
26-10-2004, 08:41 PM
PM sent...
26-10-2004, 10:46 PM
Thanks dexter, I insalled and made a surface scan from SpinRite yesterday. Oh my god, the hdisk had almost 75-90 MB of Bad sectors and all are fixed and now only 1 is there (ie 8 KB). Hats of to the SpinRite people.
Navaneeth
Search this Thread |
