Old 18-01-2006, 04:14 PM   #1 (permalink)
::cyborg::'s Avatar
Default CTFMON.EXE KILLING ME
i dont know how to get rid of that file ctfmon.exe from the time i have office xp installed i get that stupid file im my task manager and it is eating 3-4 mb of my ram
i have tried renaming the file and also unchecked the startup from the msonfig but this file is not going helppppp!!! :roll: :roll: :roll: :roll: :roll: :roll:
::cyborg:: is offline
Old 18-01-2006, 05:46 PM   #2 (permalink)
phatratt's Avatar
ctfmon.exe is installed when you install office XP.to remove it from msconfig you need to delete the registry at HKEY_LOCAL_MACHINE>software>Microsoft>sharedtools> MSconfig>Startupreg>ctfmon.exe
Just delete the key.
P.S:Always try to backup before modifying the registries.
phatratt is offline
Old 18-01-2006, 07:18 PM   #3 (permalink)
I believe ctfmon will come back even if you remove it from startup... To properly remove it, you should see http://support.microsoft.com/kb/q282...22120121120120 for details wherein you have to uninstall Alternative User Input, then remove it from Text Services, and then uninstall a couple of dlls.
Arun
sakumar79 is offline
Old 18-01-2006, 10:00 PM   #4 (permalink)
String Phreak
mediator's Avatar
Hey thats a problem that nearly killed me! So I switched back to Office 2000 premium. I dont like Office Xp bcoz
1. ctfmon.exe problem
2. Whenever u go for cliparts it starts searching the hardisk for images....
So I reverted back to office 2000 as it starts faster also and not much difference between 2000 and XP!
mediator is offline
Old 19-01-2006, 04:37 PM   #5 (permalink)
::cyborg::'s Avatar
thanks a lot u guys are great
Old 19-01-2006, 06:03 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
ctfmon.exe if situated in c/windows/system32 folder, is the legitimate microsoft office file; else a virus.
i had removed it from my startup using 'winpatrol'. try it.
ps : also click http://support.microsoft.com/kb/q282599/
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 19-01-2006, 08:41 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can try following:
Goto Add/Remove Programs list and click on Microsoft Office XP Professional with front page (or something like that), then click on Change button and select Add/Remove Features then Next and then expand Office Shared Features and click on Alternative User Input and select Not Available and finally click on Update.
It'll permanently remove that ctfmon.exe...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
